Cutting rubber horse stall mats
   / Cutting rubber horse stall mats
Sawzall worked like a charm. Sprayed the line w soapy water and the lubrication made it go like butter.
   / Cutting rubber horse stall mats #42
I don't think you needed to do anything. They cut metal. No cutting oil.
It smelled a little bit, like burnt rubber. Did it smell?
Tangent, some of the new fancy sawzall blades sure cut. Though I just used an old cheap one. I save the good ones for cutting stuff like 4x4 and such or hard metal.
I used whatever random blade I had.
Using the soapy water as lubricant made a significant difference. I thought at first as well it was not needed. It would cut through metal and a 2x4. Started without using the lubricant. It was totally useful.
   / Cutting rubber horse stall mats #44
What type blade did you use?
The blade that came with the saw. I bought some other blades that were like 5 teeth per inch, but never needed them. I am new to living in the country so don't have a ton of power tools. So I bought a 7.5 amp sawzall (Porter Cable) from Lowes. The blade that came with the saw worked just fine. If I was cutting all the way down the 6 foot side of the mat there would be a nice rubber smell near the end of the cut. So I would stop half way through and let things cool off a bit.
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
