Paul, The argument I made was that there is no way you can get the performance were getting today without the electronics that you so vehemently bemoan. You stated otherwise, even stated the "stupidity" with the argument. I simply want you to tell me a car before electronics that got the kind of efficiency that were getting today that doesn't use electronics. Instead of arguing around the edge cases, just name a car that uses a carb and gets anywhere near the HP/L and fuel efficiency. you specifically said "There goes the stupidity again! I was getting 30 MPG with carbs and making great power long before the factory was able to do it with computers" identify what car and what "great" power was.
Okie hp/liter is measure of work efficiency. given the fixed variables of internal combustion the higher the HP/L the more efficient the engine is in its ability to do work. without modern electronics, theres no way, contrary to the argument presented, that an engine can achieve those kind of efficiencies. Higher HP/L/MPG the more work the engine is squeezing out of a volume of fuel. If I get 30hp/l and 15 MPG it is less fuel efficient than if I get 50Hp/L for the same fuel mileage.
I wont even go exotic for an example: The lowly Subaru BRZ is a 100hp/l car that get 34MPG (actual not EPA, I just looked at the MPG erg on my buddies sitting in the parking lot.) Your turn, name a car with a carb that is anywhere close.
PS; According to the online "The truth about cars" the avg specific output of the 2015 model year cars is 93.3hp/L.
