What implement works best for controlling weeds, foxtails.
   / What implement works best for controlling weeds, foxtails. #81
Does anyone have suggestions on the style of S-Tines to choose? There appears to be three different styles of tines and three or four kinds of tips.
To reach 7" deep, which is max depth Gearmore specs, you will need points, i.e.: #1.
Tines 1-3/4" wide offer considerable resistance to being drawn through the soil. As tines flex and release, they resist going deeper.
Shovels, i.e.: #2, #3 are for shallow cultivation. While you show two Gearmore shovels, the Gearmore parts diagram shows only one shovel size: 7". Replacement shovels in various sizes and points are readily available from multiple venders on the internet.
All tips are readily changed on my equipment. Just remove one (specialty) Plow Bolt one nut and washer(s). Gearmore may use two fasteners per point/shovel.
I see only a single 1/2" X 1-3/4" size S-tine in the parts diagram, page 26.
   / What implement works best for controlling weeds, foxtails. #82
My Dad just used his 12-foot wide toolbar with gauge wheels - the toolbar had three rows of sweeps on it from front to back (about 24 individual sweeps). In the spring when the foxtail would start coming up he would run the depth about two inches under the ground. This killed all the foxtail and left the ground basically undisturbed to keep in the moisture.
<$3,000 for the train of Gearmore implements OP is contemplating.
I will never tell your Wife.
LOL, I Divorced her two years ago, so I can buy all the toys my little heart desires :D I got a call today and they have the 5' UnverFerth Perfecta in stock where I live for $2,300. Also I found out that gearmore does not build their cultivator in Chino Ca., there another company that just slaps their name on it, its built in Washington by someone else.
Thanks for the info Jeff, the UnverFerth dealer gave me this info on their tines, he said you can't run the 7" sweeps on the standard S-tines, only on the heavy duty, so I think it would be wise to order the cultivator with the heaviest S-time they make so I can use any size sweeps that I choose.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2005 Interstate StreamLine 14ft T/A Enclosed Cargo Trailer (A55973)
2005 Interstate...
1990 MACK RD688S (A58214)
1990 MACK RD688S...
