Separating the head from the block on a YM3110d to replace a head gasket
   / Separating the head from the block on a YM3110d to replace a head gasket #21
sounds just like mine
   / Separating the head from the block on a YM3110d to replace a head gasket #22
Hit the starter and the compression should pop that head off.
   / Separating the head from the block on a YM3110d to replace a head gasket #23
Awesome, Sounds good! Looking forward to the how to post! +1 on re-check valve adjustment after a while.
   / Separating the head from the block on a YM3110d to replace a head gasket #24
Not a bad idea to re-torque the head bolts while the valve cover is off, too.
   / Separating the head from the block on a YM3110d to replace a head gasket #26
   / Separating the head from the block on a YM3110d to replace a head gasket #27
I would hope if one did that they would have several bolts in and just barely back them out from snug. Not loose so it shoots off like firing and anvil off!
   / Separating the head from the block on a YM3110d to replace a head gasket #28
I'm still picturing a Wile E. Coyote moment :D
25ft Tag Trailer (A56436)
25ft Tag Trailer...
JLG 15 MVL MANLIFT (A58216)
JLG 15 MVL MANLIFT...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
2022 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2022 Caterpillar...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
