Separating the head from the block on a YM3110d to replace a head gasket
   / Separating the head from the block on a YM3110d to replace a head gasket #21
sounds just like mine
   / Separating the head from the block on a YM3110d to replace a head gasket #22
Hit the starter and the compression should pop that head off.
   / Separating the head from the block on a YM3110d to replace a head gasket #23
Awesome, Sounds good! Looking forward to the how to post! +1 on re-check valve adjustment after a while.
   / Separating the head from the block on a YM3110d to replace a head gasket #24
Not a bad idea to re-torque the head bolts while the valve cover is off, too.
   / Separating the head from the block on a YM3110d to replace a head gasket #26
   / Separating the head from the block on a YM3110d to replace a head gasket #27
I would hope if one did that they would have several bolts in and just barely back them out from snug. Not loose so it shoots off like firing and anvil off!
   / Separating the head from the block on a YM3110d to replace a head gasket #28
I'm still picturing a Wile E. Coyote moment :D
48" X 120" X 54" METAL STORAGE RACK W/ SHELVES (A58374)
48" X 120" X 54"...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
11' CONTAINER (A52706)
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
