Separating the head from the block on a YM3110d to replace a head gasket
   / Separating the head from the block on a YM3110d to replace a head gasket #21
sounds just like mine
   / Separating the head from the block on a YM3110d to replace a head gasket #22
Hit the starter and the compression should pop that head off.
   / Separating the head from the block on a YM3110d to replace a head gasket #23
Awesome, Sounds good! Looking forward to the how to post! +1 on re-check valve adjustment after a while.
   / Separating the head from the block on a YM3110d to replace a head gasket #24
Not a bad idea to re-torque the head bolts while the valve cover is off, too.
   / Separating the head from the block on a YM3110d to replace a head gasket #26
   / Separating the head from the block on a YM3110d to replace a head gasket #27
I would hope if one did that they would have several bolts in and just barely back them out from snug. Not loose so it shoots off like firing and anvil off!
   / Separating the head from the block on a YM3110d to replace a head gasket #28
I'm still picturing a Wile E. Coyote moment :D
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2019 GALYEAN...
NEW IDEA AVCO 1R CORN PICKER (A52708)
NEW IDEA AVCO 1R...
2023 Isuzu Dump (A56858)
2023 Isuzu Dump...
(5) CANDY JARS (A58374)
(5) CANDY JARS...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A55973)
2019 Allmand...
