ZEN-NOH YM1500
   / ZEN-NOH YM1500 #11
Although not an owner I sure enjoy the forum. Appreciate everyone letting me participate.
   / ZEN-NOH YM1500 #13
I saw this after i posted. I see California gives you credit too....also dont leave out that you were an owner for quite a few years!!
   / ZEN-NOH YM1500 #14
Winston is the man!! Wouldn't be the same forum without him. Helped me out many times too and I thank you for that!
   / ZEN-NOH YM1500 #15
I just purchased one of these tractors myself. I went to change the oil and cannot seem to find the oil plug. I don't wish to sound like an idiot, but could someone inform me as to where the engine oil drain plug is located on the Zen Noh YM1500D tractor. Thanks!
   / ZEN-NOH YM1500 #18
Thank you! It is in a precarious place, as most are to the side that I have seen.
   / ZEN-NOH YM1500 #19
Another question if I may; two days ago I removed the FEL from this tractor and took it into the shop to change the trans/hydraulic fluid. I removed the tri-plate and cleaned the screen, I drained the oil from the pan, then I replaced the trans/hydraulic oil with the standard JD 303. Everything went as it should, however now my three-point arms won't work. They will not raise or lower. I cannot for the life of me think of what the reason may be.
I took the FEL off because it had a blown a seal in one of the cylinders that was spraying oil and I thought that I would take this opportunity (while the cylinder is in the repair shop) to change out the fluids completely. The FEL and the three-point lift was working just before I took the FEL off. Any thought, ideas, or direction in resolving this would be greatly appreciated.
   / ZEN-NOH YM1500 #20
I don't know the specifics of your hydraulics but generally the loader is in series ahead of the 3-point. With the loader removed, is there still a path for the fluid to pass unrestricted through the loader valve (or some substitute) and onward to the 3-point?
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
KMC 5610 (A53084)
KMC 5610 (A53084)
Honda Mated Engine and Transmission (A50325)
Honda Mated Engine...
2001 Trail King TK18LP / TK20LP / TK40LP Paver Special Trailer, VIN # 1TKC027231B046890 (A51572)
2001 Trail King...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
