ZEN-NOH YM1500
   / ZEN-NOH YM1500 #42
Hello everybody I'm new to the fourm and I'm in need of some help. I have a YM1500 and I'm having issues with the 3 point arms not raising after I done a filter and fluid change. I was reading on here and did notice another member that had the same problem and I tried contacting him to see if he could tell me how he fixed his but I haven't got a reply yet. but if anybody has any ideas of what it might be I would greatly appreciate it.
   / ZEN-NOH YM1500 #43
If you are confident you have your suction pipe back on without leaks (hose connections, joint bolt gaskets) I would then loosen off just a tad the joint bolt where the high pressure line goes into the 3 point control. Put a rag over it and only set the tractor at idle. If you get nothing I would then remove the suction line from the top of the pump and fill the pump with fluid and try again.
   / ZEN-NOH YM1500 #44
Winston ideas are as good as any. These things self prime. Apparently this has happened before but this is the first I recall
2013 Volkwagen Tiguan SUV (A56859)
2013 Volkwagen...
Hole Punch Wheels on Frame (A57149)
Hole Punch Wheels...
GE WASHER & GE DRYER (A58376)
GE WASHER & GE...
Cummins DGDA 80kW Diesel Generator (A56857)
Cummins DGDA 80kW...
UNUSED FUTURE 24" HYD MINI TILTING BUCKET (A58376)
UNUSED FUTURE 24"...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58216)
HYDRAULIC THUMB...
