jcummins
- Joined
- Jan 14, 2007
- Messages
- 1,637
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
Suppose to wifi over wan...no wires to mobley
Works great. Can do USB to micro USB at Mobley. The Mobley port is covered with a label/sticker to peel off. Sometimes hard to see. I believe earlier in thread you'll find the configuration, very straightforward and as far as I read not the problems reported by the $80 Asus router.
I also have the ar300 but settings are the same:
I disagree. Does the job perfectly for my 15+ devices for a couple months now.A $26 router will be exactly that, I wouldn't expect much out of it.
Mine came in today. Plugged into truck outside and connected my phone via wifi. Had 10.16 down and 1.36 up. Got it rigged up in my computer room in the house and only getting 4+ down and .43 up.
Edit: Figured out where to set the no time out.
Also if you have any ideas on why my PC won't connect I'm all ears.
My PC is using a USB wifi adapter because the wired ports on my Centrylink modem died. It sees the Mobley and prompts for the password then fails to connect. So far I have connected my phone, wife's notebook, and the TV without issues. I may have to order a router and use that to get at the PC. At least I could connect back to the network by cable with a router since it's in the same area.
