Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #871
There are 3 connections
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #872
I follow several Mobley threads. In the tractor, phone, and camper forums.... It's entertaining.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #873
So i had to reboot with usb cable removed, wait for network, then plug router in.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #874
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #875
Ordered LTE antenna and cables.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #876
Maybe that's what is going on with mine. Since the last at&t refresh to the network, it has not failed. Seems if you have to mess with it....things go array.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #878
Hmm. I restarted mine the other day by flipping the switch on the power strip that both were plugged into. Didn't disconnect router and both restarted fine.
These things do seem to be temperamental and some act different than others. For the most part both my Mobley and router have been staying connected and steady except for the loss of speed the other day. Coincidental I'm sure but that started or was discovered right after logging into account to look at usage and running back to back speed tests.
I am tempted to try to open it up and connect and external antenna. Have looked at the other threads and pictures but no one has explain how easy or hard it is to get apart. Not sure I want to chance damaging it if anything has to be cut or pried but if it's a matter of taking a couple of screws out I will dig into it some day.
From what I've read a 4G LTE antenna has two connections so I assume one of the connections is for the wifi and the other two are for the incoming signal.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #879
Re: Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
Case comes off easy, sodamo had a description back around page 18 or so.
2 screws, then there are a couple tabs in middle of the sides. I take pocket knife blade and pry apart.
3 antenna connections, people say to use the one above the reset switch.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #880
Yup, 2 little screws, find and pop the tabs. Gently but easy to do once you find them.
I believe either of the 2 ports on left side of pic will work. Check while open.
I carefully drilled hole over the port so I could reassemble and poke the adapter thru.
Genie 2832 32FT Scissor Lift (A50322)
Genie 2832 32FT...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
