Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #881
Wonder if it would work better to use both connectors like this antenna has?
Antenna 1
Do the MS156 connectors on the Mobley board have a male pin in the center or a hole for a male pin?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #882
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #883
According to this picture of a MS156 coax cable connector it would be a hole.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #884
Connector male, Mobley female
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #885
Just had Mobley hooked up to 12V trailer breakaway battery that was at a charge of less than 11.9 volts. Left it hooked up and the Mobley stayed on and functional for 50 hours before it turned off. I checked the voltage of the battery, and it was exactly 8.00 V. Now charging breakaway battery and was wondering if a battery tender would run the Mobley on it's own.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #886
I use a multi USB wall charger (mines 4, but a dual would work) a USB 5v to 12v converter with 2.1mm end, and a 2.1mm pigtail with small spade connectors on pins 4 and 16. Whole thing is taped to my window with 3m packing tape.
Same charger powers the GLi modem. If the Mobley needs to go with me, I unplug the pigtail and hook it up to the same type USB 5v to 12v cord in the car or RV. This way all the wear is on a cheap pigtail and not the Mobley or OBD2 pins..
Amazon.com: RAVPower 4W 8A 4-Port USB Charger Charging Station with iSmart Technology (Black): Cell Phones & Accessories
Amazon.com: KUNCAN Dc 5v to Dc 12v Converter Step Up Voltage Converter 5ft Am to Dc 5.5 x 2.1mm: Electronics
Amazon.com : iMBAPrice iMBA-CCTV-PGTM-1 CCTV Security Camera DC Male Power Plug Pigtail Cable - Pack of 1 (Black/Red) : Surveillance Camera Cables : Camera & Photo
If someone really wants a OBD2 pigtail, this one is good quality and cheap, but no DC-DC convertor: Amazon.com: 16 Pin J1962 OBD2 OBDII Female Diagnostic Connector Cable Pigtail: Automotive
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #887
I don't know for sure, but I don't think it puts out pure DC.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #888
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #889
Re: Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
I have to ask, what is it about this tech that is driving people to it. No pun intended.
Is it the unlimited data at 20 dollars? And if it is the unlimited at 20, do you still have cell phones for voice?
Or is it the mobility? Seems the masses are making it a fixed spot device.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #890
I replaced my exede satellite 10 GB/$50 month plan with it. Going to add remote antenna. Still got cell phone w data, but might reduce that data plan.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52128)
Michelin CARGOXBIB...
Danhauser 3 pt Post Hole Digger (A50515)
Danhauser 3 pt...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
