PTO SHAFT CUT TO SHORT
   / PTO SHAFT CUT TO SHORT #1
joesco
Folks,
I had to cut my PTO shafts ends on my chipper for it to fit on my newly acquired BX2230. Yesterday, taking advantage of HF's 25% sale, I purchased a 3pt Hitch Quick Attach.
I installed it this morning and attached my chipper (what a breeze!) and now the shaft is to short. Can I just replace the shaft parts or do I need to purchase an entirely new PTO shaft?
Thanks very much!
   / PTO SHAFT CUT TO SHORT #3
Folks,
Thanks very much!
traded a Kubota B2650 to a Kubota L3901 which ended up making my drive shaft to short on the Rotary mower. Took the shaft to my Kubota dealer (Barlows) and told them I needed it stretched. Came back some days later and behold I had a longer drive shaft that then had to be cut off a bit. They have this new machine that will stretch drive shafts, said it was a really expensive machine. Or some would rather believe they took the end off one end of the drive shaft and removed to short section and installed a new center part of the shaft. Saved some money over buying an entire new longer drive shaft.
Always remember if you don't like my answers/posts there is a section where one can block someone on TBN and never see any of their posts again as I've done with a few over the years. :D
   / PTO SHAFT CUT TO SHORT #7
I ran into the same problem on my tiller. I bought the outer piece of tube from my dealer and took the old tube out of my yoke and installed the new one. Mine was to short even with the extender. Works fine now
   / PTO SHAFT CUT TO SHORT #8
Folks,
Thanks very much!
Your pto shaft will have the inner and outer metal tubes made to be easily removed and replaced. A spring pin holds each tube to its respective yoke.
You might need at least one of the plastic shield pieces to be safe when done but this will be cheaper than a n complete new shaft and will have the shear bolt design the equipment manufacturer felt best to use.
Dave M7040
Dave M7040
Great, thanks very much!
   / PTO SHAFT CUT TO SHORT #10
looks like your question has been answered very well by the forum members.
might also keep in mind that in general, shaft problems can also be handled by a good drive line specialist.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
WESSEX RMX500 LOT NUMBER 45 (A53084)
WESSEX RMX500 LOT...
