ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #54
As
Did your mower come in yet ?
Yes. Yesterday I think. Needing to go pick up a trailer on Monday and then try to find some time to get it. They have it ready and parked inside a covered barn to keep it out of the sun. I think it still needs the canopy installed. It's going to be nice having a smaller trailer again
Brett
Completely Satisfied Customer
Rear discharge had slower blade speed was one of the biggest negatives I could find but that might not be a negative ...
The 60" RD BTS is much slower at 16k.
The 72" RD BTS Is 18k rpm & really cuts a lot finer cut.
I am truly Amazed with my ZD1211 72" RD :D
Rear Discharge Decks exhaust THICK TALL Grass Clippings so much faster than a SD Deck slowing you down for clippings to be processed into thick clumpy windrows.
72" Rear Discharge Blades 2.5" wide with 1-1/8" center hole :
K5698-97530 is OEM replacement box of 3
K5698-34340 is a single blade OEM
70000-25013 is a single blade "High Lift" & EXACTLY the SAME Blade as the OEM stock replacements.
Kubota must be changing part #'s
K5975-34460 is the curved looking mulching blade.
The new style side discharge blades are 3" wide, flatter cutting edge with a bigger center hole than the RD uses.
Just a little FYI for you Tech Guys :D
2018 Lexus IS300 Sedan (A55853)
2018 Lexus IS300...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A57024)
2017 Yale GLC050VX...
2016 VOLVO L45H WHEEL LOADER (A52707)
2016 VOLVO L45H...
