rustyshakelford
Veteran Member
Went to a dealer today & drooled all over a ZD1511 72" Rear Discharge unit
Man I like it but just ain't sure on tier4 DPF BS.
Then get the 1211. Ours should be in at the end of the week supposedly.
Brett
$4 Grand MORE for 6 extra hp.
Us farmers & shade tree guys are clueless when tier4 electronics starts acting up.
I just couldn't make myself pull the trigger today on the ZD1511 "Tier4 LawnMower".
I always buy the bigger engine on EVERYTHING I buy, BUT the Tier4 is pushing me towards the ZD1211 24hp.
The ZD1211-72 frt & rear axle widths looks the same as the ZD1511-72 as far as I could tell ?
Both has 61.4" wheelbase.
I turned the blades to 3&9 o clock & visually looked at them from frt of deck, today in the showroom.
I'd estimate 3/4-7/8" blade overlap. Not near as much as I'd like to see :-(
When tips of blades get worn off from grit & pebbles at 18k rpm, you have VERY LITTLE blade overlap.
IDK why mower mfg's don't have 1.5+" blade overlap like Bush Hog RFM do.
They could move center shaft housing out more & use longer blades.
Didn't you notice how thick those blades were? What did you think about that?
Brett
The rear discharge deck also has a narrowed discharge opening so the opening isn't 72" wide and the grass gets double cut on the Rear discharge the way it's designed ...
