ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP
   / ZD1511 72" REAR DISCHARGE INFO & BLADE OVERLAP #54
As
Did your mower come in yet ?
Yes. Yesterday I think. Needing to go pick up a trailer on Monday and then try to find some time to get it. They have it ready and parked inside a covered barn to keep it out of the sun. I think it still needs the canopy installed. It's going to be nice having a smaller trailer again
Brett
Completely Satisfied Customer
Rear discharge had slower blade speed was one of the biggest negatives I could find but that might not be a negative ...
The 60" RD BTS is much slower at 16k.
The 72" RD BTS Is 18k rpm & really cuts a lot finer cut.
I am truly Amazed with my ZD1211 72" RD :D
Rear Discharge Decks exhaust THICK TALL Grass Clippings so much faster than a SD Deck slowing you down for clippings to be processed into thick clumpy windrows.
72" Rear Discharge Blades 2.5" wide with 1-1/8" center hole :
K5698-97530 is OEM replacement box of 3
K5698-34340 is a single blade OEM
70000-25013 is a single blade "High Lift" & EXACTLY the SAME Blade as the OEM stock replacements.
Kubota must be changing part #'s
K5975-34460 is the curved looking mulching blade.
The new style side discharge blades are 3" wide, flatter cutting edge with a bigger center hole than the RD uses.
Just a little FYI for you Tech Guys :D
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
378721 (A54865)
378721 (A54865)
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
