1951 B - Temperature Question
   / 1951 B - Temperature Question #1
rmonio
New Market, MN
JD 4600, JD B
My new (old) 1951 JD B's temperature gauge isn't showing any temperature - even after 2 hours of spreading manure. The unit doesn't seem hot and the blinds arn't too hot with the air. However, if the gauge isn't showing anything, should I be thinking the gauge and sensor are bad and they should be changed out?
Someone had told me there is a kit that combines all together - is this true?
Happy to get recommendations and thoughts from the folks here.
Thanks for your help!
-Bob
   / 1951 B - Temperature Question #4
If you want a restoration quality gauge contact Jerry Trcka. His are correct and will read right. I got one years ago for my A (first tractor) from one of the other parts suppliers that always reads low, total waste of money. Google his hame or use Facebook.
   / 1951 B - Temperature Question #5
Just drain the coolant level down below where the sensing bulb goes in. Once you remove the sensing bulb it is very easy to test the temp gauge, by putting the bulb in a small pot or cup of boiling water. Then see if the gauge works.
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
Wolverine 3Pt Forks (A59814)
Wolverine 3Pt...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
17501-FL (A56857)
17501-FL (A56857)
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
