Drilling holes in steel
   / Drilling holes in steel #32
   / Drilling holes in steel #33
bcp
Step drill bit works great and your 1/8 pilot is the next best method .
   / Drilling holes in steel #34
Buy extra arbors so that each cutter has its own. A small investment for time saved.
Terry
That's a great idea. This is one complaint I have about this kit. After using a cutter, it's a PITA to remove from the arbor as the twisting action causes it to lock on even tighter.
Edit: Well maybe I won't after all...The arbors are over $20 a piece!
   / Drilling holes in steel #35
I drill up to 1" holes with a steel bit in my drill press that only slows down to 225 rpm's. I sharpen the bits myself and have learned the angle that works for me over the years. Nothing scientific, just a grinder and an eyeball. The pilot hole sizing is imperative as well and a little lube :)
BTW don't buy a Rigid drill press from HD, it sucks, the arbor wobbles. I went back and b@#$%&d about it but they told me the next one would probably be just as bad! So I'm stuck with it.
I've been on the hunt for a good old drill press , one of these days I will find one on CL.
   / Drilling holes in steel #36
Really!
Mine came off the tool truck that used to call on me. I'm uncertain what I paid for them but I'm sure it wasn't that much even considering I was the smallest "customer" on his route.
Must have been the tunes and my sunny disposition!
Terry
   / Drilling holes in steel #37
Terry
I am discovering this little trick very slowly over years. :newhere: I realized after collecting a few hole saws that were trashed, the arbor was worth having around. I do usually separate mine after a job to clean out the hole saw so it doesn't contaminate the next job depending on material.
ROCK PICKER (A52472)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
