Drilling holes in steel
   / Drilling holes in steel #32
   / Drilling holes in steel #33
bcp
Step drill bit works great and your 1/8 pilot is the next best method .
   / Drilling holes in steel #34
Buy extra arbors so that each cutter has its own. A small investment for time saved.
Terry
That's a great idea. This is one complaint I have about this kit. After using a cutter, it's a PITA to remove from the arbor as the twisting action causes it to lock on even tighter.
Edit: Well maybe I won't after all...The arbors are over $20 a piece!
   / Drilling holes in steel #35
I drill up to 1" holes with a steel bit in my drill press that only slows down to 225 rpm's. I sharpen the bits myself and have learned the angle that works for me over the years. Nothing scientific, just a grinder and an eyeball. The pilot hole sizing is imperative as well and a little lube :)
BTW don't buy a Rigid drill press from HD, it sucks, the arbor wobbles. I went back and b@#$%&d about it but they told me the next one would probably be just as bad! So I'm stuck with it.
I've been on the hunt for a good old drill press , one of these days I will find one on CL.
   / Drilling holes in steel #36
Really!
Mine came off the tool truck that used to call on me. I'm uncertain what I paid for them but I'm sure it wasn't that much even considering I was the smallest "customer" on his route.
Must have been the tunes and my sunny disposition!
Terry
   / Drilling holes in steel #37
Terry
I am discovering this little trick very slowly over years. :newhere: I realized after collecting a few hole saws that were trashed, the arbor was worth having around. I do usually separate mine after a job to clean out the hole saw so it doesn't contaminate the next job depending on material.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
40' CONTAINER (A51244)
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
