Rock Crawler
- Joined
- Aug 15, 2017
- Messages
- 2,226
- Location
- Pittsburgh, Pa.
- Tractor
- 2021 Kubota L3560 HSTC, 2011 Craftsman Excellerator GT (680hrs), 2018 Husqvarna TS354XD, 2017 Husqvarna HU800AWD, 2019 Kawasaki Mule Pro DX (Yanmar)
We got the BX last week used with 93 hours on the clock and noted that the 50 hour service was not completed. So the start was to run to a dealer and buy all fluids for engine, front axle and rear axle as well as all filters including the 2 fuel filters. Around $300 later we were off to the garage to do a complete change of fluids and filters including the hydro screen. That was completed in a couple hours and out of the way, so we wanted to get a feel for the little machine and what we could do.
So next we head down into the property to a camp fire party area that we use that naturally is on a slope. We don't have flat property where we live, so I really was interested in collecting clay/dirt and moving it to the camp fire area so that it would be level. You know, minimize the drunks falling over in camp chairs!
First thing noted was that unlike a larger machines, you loose a ton of lifting/curling power to the front loader while you are pushing forward with the machine, it is as if the hydraulic power is being split or shared between the 2. So if your pushing forward into dirt/clay and you get stopped, you often can not simply curl/lift and get moving while spinning the tires, your forced to stop motion so that you gain the ability to curl and them get moving and rotate the bucket in again. It's a baby tractor, so I guess this is part of the technique.
The backhoe has a similar issue, if your trying to multi-control the curl, the dipper and the arm to dig the power is greatly reduced across all. Use 1 or 2 at a time and you can often find more power. It just does not have the hydraulic performance to work the controls as you would on a larger backhoe. Baby machine limitations.
My buddy told me on day one to get a skid on it right away. Well, 4 days in and I cleaned the fan blades off of the HST fan. A stupid little stick went up and hit the blades and in less than a second I heard the fan hit and the blades went scattering around me. I need to get a skid! I have the old fan off, and it's waiting for new parts.
Overall, I had to learn the techniques for working with such a small and limited machine. It will work, and it will do what you want, you just have re-learn how to work around the limitations.
In 10 hours of engine time I was able to move a massive amount of dirt to level out our camp fire area, I used the loader to cut dirt from logging roads above the camp area and carry it down to dump, back drag and pack in layers until I built up around 3 feet to the low end of the fire pit area.
I also put my 11 year old boy to work removing stumps from an area that my older son once built some form of cabin. He flat topped small trees to use as floor supports, and the cabin thing has fallen, but the tree stumps remained. I put my younger boy to work with the backhoe and he got amazingly good at controlling it in just 15 minutes. Heck, he is better at the backhoe than me with maybe 2 hours of total life exposure to a backhoe. Kids learn fast.
Overall, my impression changed from disappointment to respect of this baby tractor. It's not a construction grade machine for doing hard work fast, but it will do hard work and a lot of it at a pace that you and a shovel would die trying to do. Once I learned how to work with it, it becomes a pretty effective and efficient machine for getting work done. A larger tractor (Kioti CK2610?) would surely dig better and faster, but is it worth over 2X the money when I am not doing this for pay? Likely... no. Plus, I can throw a belly mower under this and cut my near 3 acre yard in similar fashion to my garden tractor where a CK2610 would an unwieldy beast.
Back to the HST fan, I did not like the idea of stripping the seat, controls, removing the rear body, remove the hood and lift and pull the engine forward to get to the fan. That sounded painful. Instead, I pulled the front driveshaft CV from the crankshaft yoke. Removed the front CV from the shaft. Removed the crankshaft yoke. Removed the rear CV from the shaft. Spun the fan so that the half circle cut out was at obout the 8 o'clock position and removed one transmission bolt, then reached into that half circle cut out with a shallow 12mm socket on a 3/8" universal and a 6" extension and got the rear axle/driveshaft yoke clamp bolt out. At that point I was able slide the entire yoke forward and remove the 2 bolts holding the broken fan hub on. I plan to reassemble in reverse order. Total time to disassemble was about 1 hour and 10 minutes. Everything is being done with the tractor on jack stands and working from underneath. I do not want to make a habit of doing this, so I am ordering a skid plate pronto!
A picture of the celebratory camp fire after getting the fire area all leveled out and smooth. I like it!
