ibldrc
- Joined
- Sep 23, 2017
- Messages
- 24
- Location
- Pooler, GA
- Tractor
- 1 each of Yanmar, Cub Cadet, Kubota, 2 JD
I'm working on a Zen-noh Yanmar, either a 22 or a 24. The Zen-noh labeling says 22 but the gauge cluster says Yanmar 24. I'm not concerned about which one it is at this point. The engine runs fantastic, and it's in fair overall shape other than the gear problem. I know parts may be scarce, in fact my original reason for the purchase was strictly for the engine, but I'm thinking maybe we can save this one. It would be a shame to part it out, as it's still in good shape.
I've taken some pics, and done some initial troubleshooting, and here's where we're at:
Engine running:
The clutch works, the PTO drive works in all gears.
I have been able to get it to move in gear for about a foot, but with no consistency. I'll have to push it by hand a bit, then it will move and stop.
With both shift levers in neutral, clutch engaged, it will knock a bit, like something is floating around in there getting kicked about.
No abnormal noises with clutch depressed.
Engine off, decompression lever engaged, clutch engaged, and gearbox top cover removed:
At least one broken tooth in what I think is second gear, see below.
With the rear tires raised, RH gear shift in neutral:
LH gear shift in first, moving the wheels together to lock the diff, there is no movement.
LH gear shift in second and third, the upper LH "inside" shaft will spin when the wheels are turned together by hand, and a timed knocking can be heard and felt.
here are some pics and video link (tried to upload but too big):
YouTube
Engine running:
YouTube
