1949 8N Won't Start
   / 1949 8N Won't Start
Thanks Soundguy, I knew I could count on you to teach an old dog new tricks.
   / 1949 8N Won't Start #32
New to you trick. ;)
All my tricks are old and well used.
And I'm trying to learn as many of them as I can from you as well.
   / 1949 8N Won't Start #34
Didn't you say gas is pouring out of the carb?
Gas did drip from the carb the other day, but not today.
   / 1949 8N Won't Start #36
Better check that out man. If gas is filling your intake pipe and dripping out that's your problem.
   / 1949 8N Won't Start #37
I guess I should have made myself more clear. The test light goes on the two posts with small wires. Not the center post at all.
   / 1949 8N Won't Start #38
I'd try a different condenser if you haven't already. Sometimes new ones are bad. Sorry if it's already been mentioned, sometimes I don't read everything.
   / 1949 8N Won't Start #39
You simple have no idea what you are talking about. ;) respectfully
I'm guessing you've never seen a ford tractor front mount coil..
1 primary wire on top.
Bottom of coil that clamps over the distributor, and 4 nipple cap has a pigtail primary wire which touches a concave head screw in the distributor to feed the points, and then the secondary is a flat thin metal spring tab that rides a conductive nub in the distro cap.
Its not a standard 2 wire and one tower round coil.. Its actually square..
   / 1949 8N Won't Start #40
My,my,aren't we peevish today? I'm sure pmsmechanic has seen a fair number of Ns but simply misstated what he was thinkin. There's enough inaccuracy in this situation to go around but there's better ways of pointing them out. I wager every single person that read the below comment by Tractorable know's there's other reasons for gas dripping from air intake (most common is overly choking while trying to start) but not a one hurled a barb at Tractorable over it. If you must rebuke someone,advise Batman he shouldn't start multiple threads about this same problem.
Fuel leaking from carb means either the float valve is sticking open or gas has leaked into the float itself and it no longer floats to close the valve.
Disassemble carb per above and check for sticking float valve and/or fuel inside the float.
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
LANCER MODEL HL125 - 4' TILLER (A51243)
LANCER MODEL HL125...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
Homemade Head Cart (A50514)
Homemade Head Cart...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
