I guess my engine block heater is bad?
   / I guess my engine block heater is bad? #1
cfb
Cleveland, Ohio
1949 Ford 8N, Ingersoll 448, Ford 16HP Diesel
Hello,
after the first winter or two of hard starting, I had the dealer install an engine block heater to my Ford 16HP diesel. One of my better decisions. That was about 25 years ago. It went well below freezing the other day so I plugged in the tractor. Was hard the next day but started okay as I have a relatively new battery. Same thing the next day, so-so starting. So today, had it plugged in overnight, sluggish again. This time I felt the engine and it was cold as can be. It worked all last winter.
I was hoping there was fuse in the line, but it is a straight cord.
So, before I take it to the dealer, is it common for these to eventually go bad?
Now that there is a plug inserted into the block, would it be easy for me to replace it myself rather than the dealer? Would someone just take a second to explain how the heater works. I thought the purpose was to heat the diesel fuel. So the heater element is in the block, I think in the block where the anti-freeze flows. The engine oil must get warm too I suppose, but indirectly. The three injectors are in the engine, so are they too indirectly being heated up too?
thanks. cfb
   / I guess my engine block heater is bad? #2
I’m sure others will chime in, but here goes ... It is the coolant in the engine block that is being warmed directly by the heater. The warming of the block (the objective) is indirect. You need to find out the route by which your heater is secured to the block. It might be a straightforward replacement that you could do yourself. Frank
   / I guess my engine block heater is bad? #3
Before changing the block heater unplug the cord off it and check for continuity. You may only need a new cord.
   / I guess my engine block heater is bad? #4
The hard part is installing the first one, because you have to knock the frost plug out. Replacing one is easy.
   / I guess my engine block heater is bad? #5
I second this suggestion. Over the past 40+ years I have had far more failures of heater cords than heaters. In fact IIRC the only actual heater failures were a couple of the in-line rad hose heaters.
   / I guess my engine block heater is bad? #6
Many have a cord that plugs into the block heater. Remove this cord and check heater and cord for continuity. One can buy separate cords.
Thank you everyone. I have to brush up on how to check continuity. I tried pulling the cord plug at the element but seemed hard, so maybe I just need to pull a bit more, but it has that orange plug just like Egon shows. The cord was nicely secured , no dangling whatsoever, just about 3" at the end so I could plug it into an extension cord. cfb
   / I guess my engine block heater is bad? #8
No need to pull harder,you might break it. Test continuity between prongs on plug that go's into extension cord. If you don't have continuity,THEN you can worry with testing cord and heater seperatly. Make sure engine is cold while testing,good heaters have a t-stat that break continuity when coolant is warm. If you have continuity,check glow plugs and control circuit.
Jaxs,
well, I did get the plug off the element. I used pliers and it came off without too much effort.
I have a multi-meter. It does work as I get accurate readings for a 12v battery and house current. Is my continuity the symbol of an arrow left of plus sign? I did put probe ends on the cord prongs and the meter stayed at #1. The meter does go toward zero when I touch the probes together. I also changed the meter to the lowest setting of ohms and again the meter stayed at one. I did the same two tests on the outside prongs of the element itself and got the same results. Did I do this correct and do you think then that both cord and element are bad? The cord prongs are not corroded and solid at both ends. Element prongs look clean as well.
I'm pretty sure the glow plugs are good, but what does that have to do with the block heater? thank you.
   / I guess my engine block heater is bad? #10
Jaxs,
You need to check the cord, end to end, each conductor separately. That should make the needle go toward zero, if not all the way, then nearly. Across the terminals for the heater, try different resistance settings (ohms) and see if you get anything on any scale. If so, report that number here. A very high resistance (including infinity) indicates that it's burned out.
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
