Winter Projects
   / Winter Projects #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
This past spring I finally installed a high efficiency propane furnace in the 900 sq ft shop on California's north coast, so I can work comfortably in the winter. I've been trying to tough it out but finally gave up. It isn't cold compared to the central part of the country but it is too cold for me. Now looking forward to a much more productive winter. First job is getting my wife's old sports car back on the road. Also my old Norton Commando. And at least one tractor project. I am going to graft my 30-year old Harbor Freight engine hoist onto a SSQA plate to make an adjustable jib. Already took the hoist apart and got started on the car.
   / Winter Projects #2
If it's cold ( 30F and below for me) I have little motivation to leave the house. A heated workspace is extremely nice.
   / Winter Projects #3
Those to projects you should get any cabin fever. ;)
   / Winter Projects #5
I’ll be watching your engine hoist project. I have the 1 ton version.
   / Winter Projects #6
Pat,
I have a propane furnace in my shop with the thermostat set on 60F degrees. I also use a wood stove. Depending on the project, I like the temp around 70F. So in the mornings I stoke the wood stove and fill it before I go to the house in the evenings. Last year I burned 113 gallons of propane. I "live" in my shop in the Winter. I checked out this thread to see what Winter Projects would show up. I get some great ideas from threads like this!!!!
As to the Norton. Good friend of mine had an 850 Commando in 1980. I had a Honda 750K. We were both in the local Army Reserve unit. We rode our bikes to Ft McCoy Wisconsin for training one Summer. The Norton blew a head gasket on the tip up there. We were only going to be there 2 weeks. George got ahold of a JC Whitney catalog and ordered a new head gasket. It showed up in the mail and we installed the new head gasket on the first floor of the Army barracks.
On that same trip him and I were sitting at a stop light, gave each other the "let's race" nod. Light turned green and I took off. Got down the street half a block and I don't hear George, where's he at??? Quickly turned around and went back to the intersection. There was George in the middle of the intersection trying to push the Commando off the street with the back tire sliding!!!! It had busted the chain tightener and wound the chain up on the transmission sprocket locking the back tire!!!! After I laughed at him uncontrollably for a minute I helped him get it off the street!!!! That was a very cool bike!!! Post your progress on yours. Heck, post a pic of it as it sits now!!!! His was silver in color.
   / Winter Projects
I used to joke that the Norton was like a helicopter, 4 hours of maintenance for every 1 hour of flight time. But it was a great bike. These days I am sure any of the common Japanese sports bikes could run circles around it. Will get a photo up!
   / Winter Projects #8
But can you order a head gasket set and get it within two weeks, and then install it in an Army barracks with common hand tools on a common Japanese sports bike??? :)
   / Winter Projects
Norton pix. I am starting with the lighting, like all older British vehicles the electric stuff is marginally functional.
   / Winter Projects
Pat,
I don't use a wood stove, but for several years I got by with this fan in the ceiling. Above the fan there are two 8" sonotubes that go up to the peak of the attic. On a sunny day the air there is 105-110 degrees. The fan (a $50 window fan) goes on automatically and pulls the hot air down into the shop. It will raise the temperature to 60-70 degrees depending on outside temperature. IF the sun is shining on the roof. If the sun is not shining, it doesn't work at all. So I hope to limit use of the furnace primarily to December and January, when the sun is low in the sky and it is overcast most the time anyway.
   / Winter Projects #11
Awesome!!! I on the other hand am already heating to keep my shop warm.
In my World the secret is to never let the shop get cold. My building and the concrete under it are kept warm all season. Then it's sooooooo much easier to raise the temp a few degrees. :)
   / Winter Projects #12
I heat my house with wood and it works well since it's in nearly continuous use. I heat my shop with natural gas. It's a lot better suited for a couple hours of use and warms up a lot faster.
   / Winter Projects
The red car sits just a few inches off the ground so working underneath is not easy. I don't like the idea of working underneath jack stands. I also don't like the idea of spending several thousand dollars on an automotive hoist. Looking through the Summit Racing website I came across these foam blocks. Never used to be anything like that, anyway new to me. They raise the car 12" which is plenty of room to work, and are very solid. And, they are made in Michigan with American-made raw materials.
   / Winter Projects #15
So ..... why are these safer than properly rated steel jack stands?
   / Winter Projects #16
I've seen some " properly rated jack stands " that I wouldn't trust a lawn mower on. I've got a set of 12 ton jack stands that I trust. I'd take his blocks over 98 percent of jack stands.
   / Winter Projects
It is a good question one I have thought about too. Growing up we worked on cars a lot, and generally cribbed up under each tire with 2x and 4x lumber if we were going to do serious work underneath. That was completely stable and safe. Jack stands were OK for example when supporting an axle to do a brake job. I like these blocks because they are like cribbing except more convenient. Also, my jack stands (I have 4 sets) would be right at the top of their extended height to raise the car that much, probably not advisable. The blocks are rated for 1500 lbs each, the whole car only weighs 2300 lbs, so there is a good safety factor. And they cannot slip, bend or fall over. A couple weeks ago when planning the winter work I googled "jack stand failure" there is lots of bad news out there.
   / Winter Projects
Got the tractor-mounted adjustable jib just about done. The whole thing is made from cut-off pieces of the old engine hoist. The only new parts are the two 5/8" bolts that hold the back brace, SSQA plate, and mast together. We are traveling to visit family for Thanksgiving, so will finish up when we get back. I will do a write up for Build It Yourself when it is done.
   / Winter Projects #19
My winter project is just the usual 'woodpile maintenance'. I have about 7 cord of rounds to split and stack. I put in an hour or more a day, weatehr permitting, manually splitting and stacking. I have a hydraulic splitter but it only sees the tough stuff, knots, forks, etc. Rest gets introduced the to X27 Fiskars, 6lb maul and 8lb wedge and sledge Rest of the time is spent in houses. No heat in the garage/shop.
   / Winter Projects #20
While I don't have heat in my outbuildings, I spend winter months doing clean-up and clean-out. The rustic garage is way out of control and needs a general reorganization with better use of wall space. The shed has a ton of stuff purchased at auction. The problem comes from mixed boxes where I buy the box to get something specific but it comes with a lot of other stuff. Sometimes I just want the box -- like wooden advertising boxes -- and they come with fan belts, big files, tin snips, and a tangle of hose clamps. If sorted out [so I can find it later] a lot of this is good stuff. But how many files or hedge clippers do I need. So I need to take some time and do the old "keep, sell/donate, toss" sorting exercise. Even if a little cold, its not too bad in the buildings providing the wind is quiet [unlike today].
2015 UTILITY VS2RA 53FT REEFER TRAILER (A59905)
2015 UTILITY VS2RA...
2020 KOMATSU HM400-5 OFF ROAD DUMP TRUCK (A60429)
2020 KOMATSU...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
BUYERS PREMIUM & PAYMENT TERMS (A59904)
BUYERS PREMIUM &...
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
