Fluid running down inside of front tire... what to check
   / Fluid running down inside of front tire... what to check #1
erkme73
Middle TN
Mahindra 2555 HST Cab
New to tractor ownership (< 2 weeks). Discovered a line of fluid (oil?) running from rim to ground on the inside bottom of the front DS tire. Haven't had a chance to get a close look.
I don't have a trailer to haul my tractor, and the dealer is about 40 min away. I still have 4 months of the bumper-to-bumper warranty left. Is this something I should tackle on my own, or should I try to get the dealer involved?
   / Fluid running down inside of front tire... what to check #2
Let dealer take care of it while it’s under warranty. It might just be a seal or it could be serious. Under warranty call dealer.
I think that's the way I'll go - but from what I understand, the dealer won't cover transportation to/from their location. Might have to research that a bit.
   / Fluid running down inside of front tire... what to check #4
Let the dealer take care of this situation. It could be serious - something you are not prepared to repair.
   / Fluid running down inside of front tire... what to check #5
Have you added fluid to the front hubs and that overfilling might be a factor? If not, it's the dealer's problem.
   / Fluid running down inside of front tire... what to check #6
Warranty usually won’t cover pickup/delivery. However, sometime being very nice to the dealer will help with the cost of it. Call them tomorrow and tell them what’s going on and see what they say
Brett
That is the plan, Brett. Since I've only had it for two weeks, I'm trying to shake out any remaining gremlins, or find any other issues that might require their attention. I'd hate to get it to them without a comprehensive list of things. There's a pretty good chance this will be the last transport to the dealer while still under warranty.
I've notice the following:
1) Slow drip from the QD fittings under the step
2) MIL comes on frequently if I don't keep engine RPM up (I know this is an issue with the EGR/mCRD design - but maybe there is newer firmware?)
3) Leaking front DS wheel
4) OBDII error reports two codes (engine overspeed and EGR exceeded learning curve limit)
5) Wiper fluid takes a good 30 seconds to prime and reach window (I know, petty, but hey...)
Anyway, I'm having a 60x40 barn built this week (concrete slab) that will help me get a better look at everything. I hate to approach the dealer with a long list of seemingly petty things. I only hope they can sympathize with my desire to get one last good look at everything before liability shifts to my wallet (in mid-Feb).
No. In fact, I'm so green, I don't even know how to check all of the fluids. The previous (original) owner was killed by the tractor (the trailer it was on rolled over him) - and his wife had already sold many of the implements, the trailer, and the tow vehicle which contained the owner's manual.
On my to-do list is to get a new manual and have full service performed (probably when it goes in for the warranty work). There are 130 hours on the tractor, and 50 hour service was performed by the dealer.
The dealer recently changed from a flat-fee for on-site service, to an hourly rate which begins when they leave the shop, and stops when the get back.
   / Fluid running down inside of front tire... what to check #9
On my tractor it was the seals on the pivot. Pretty cheap and not a bad repair if you're mechanically inclined. I'd way rather do It myself as drive 160 miles. I'd expect free seals from the dealer and I'd try to get $50 for my troubles. The $50 wouldn't be a deal breaker.
   / Fluid running down inside of front tire... what to check #10
Any short dogs in the area. My collie could not go by a tire a tire without marking it.
2017 Ford F-250 (A55973)
2017 Ford F-250...
Brillion 3Pt  5' Seeder (A59814)
Brillion 3Pt 5'...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
