Improving the visibility of oil on an engine dipstick
   / Improving the visibility of oil on an engine dipstick #22
Not the least of which is laying the unmodified stick on a clean paper towel.
I find that sometimes oil smears upward on one or other side of the stick. When so, you really need to see the low side.
   / Improving the visibility of oil on an engine dipstick #24
I like to go with whatever is the least amount of work.
I pull it out, wipe it off, stick it back in, pull it back out then call my grandson over to look at it.
We are talking dipstick so remember that
   / Improving the visibility of oil on an engine dipstick #25
Flashlight!
   / Improving the visibility of oil on an engine dipstick #27
Around here we use a sight glass on the oil pan of irrigation engines. You do need to remove the oil pan and add a pipe threaded opening. You can even check the oil level while the motor is running.
   / Improving the visibility of oil on an engine dipstick #28
Whew!!! Thank God!! :ill:
   / Improving the visibility of oil on an engine dipstick #30
The amount of trouble some people are willing to go through to fix a non existent problem is amazing.
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2001 John Deere 6210 (A60462)
2001 John Deere...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
KOMATSU PC360LC-10 EXCAVATOR (A60429)
KOMATSU PC360LC-10...
