Improving the visibility of oil on an engine dipstick
   / Improving the visibility of oil on an engine dipstick #22
Not the least of which is laying the unmodified stick on a clean paper towel.
I find that sometimes oil smears upward on one or other side of the stick. When so, you really need to see the low side.
   / Improving the visibility of oil on an engine dipstick #24
I like to go with whatever is the least amount of work.
I pull it out, wipe it off, stick it back in, pull it back out then call my grandson over to look at it.
We are talking dipstick so remember that
   / Improving the visibility of oil on an engine dipstick #25
Flashlight!
   / Improving the visibility of oil on an engine dipstick #27
Around here we use a sight glass on the oil pan of irrigation engines. You do need to remove the oil pan and add a pipe threaded opening. You can even check the oil level while the motor is running.
   / Improving the visibility of oil on an engine dipstick #28
Whew!!! Thank God!! :ill:
   / Improving the visibility of oil on an engine dipstick #30
The amount of trouble some people are willing to go through to fix a non existent problem is amazing.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
John Deere 2600 Display (A59814)
John Deere 2600...
