how do I get my NPT connections to not leak
/ how do I get my NPT connections to not leak #21
Store bought or cut & threaded by hand? Seldom have issues with purchased fittings with a couple wraps of teflon tape ($1 a roll thread tape is not equal to ~$3-4 a roll tape) but have seen the threads cut to long by hand cause issues many times.
/ how do I get my NPT connections to not leak #22
I stuck with NPT fittings over the years mainly because they are cheap, readily available and easily adaptable to most other fitting types when necessary. I always buy quality fittings, don't over tighten and seal with blue teflon tape. I rarely have a leak.
It is interesting to see the many different types of thread sealants discussed in this post. Although I prefer teflon tape, I've read of instances where hydraulic systems were fouled with bits of tape. The dealer assembled all 6 of the tractors I bought from him using tape and says they have never had a problem. Has anyone here seen this happen?
/ how do I get my NPT connections to not leak #23
I thought this was Teflon Tape was for or am I on the wrong page again.
Teflon tape in a valve can be a bit of a worry. I use Rectorseal, tighten everything pretty well, run it until it's hot, and then hit the one or two that dripped. I've replaced a fitting once when I couldn't get it to seal.
/ how do I get my NPT connections to not leak #24
Working offshore on production platforms the last 30 years, it is almost mandatory that you carry a roll of Teflon in your pocket. We use the same tape on piping and fittings for water, oil, natural gas and air with pressures from vacuum to 30,000 psi. It can be black iron, stainless steel, plastic, cast iron, aluminum etc. Only difference noticed is if using quality made USA tape (takes less wraps) or the cheap Chinese stuff (breaks easy).
Some pneumatic panel shops prefer liquid or paste for fittings (mostly SS), they claim it less chance of it getting into fitting.
Sometimes no matter how much tape or paste used the fitting won't seal, then it's time for a new one. Also when screwing SS to SS put extra tape on, turn is slow and don't over tighten, otherwise you will probably gall the threads, when that happens the threads will lock together, destroying the threads, making it almost impossible to unscrew and possibly leak as well.
/ how do I get my NPT connections to not leak #25
I was a pipefitter for 20+ years and generally went against what others tried teaching me. Journeymen usually said to use tape and a quality Teflon paste (I forget the brand) in a squirt tube. Generally tape, even though put on correctly, was a hit and miss as far as leaking. If I feel like redoing it a few times I use tape.
Teflon paste generally works with very few leaks.
What I found that was 99.999% leakproof was Locktite 242. If the threads are in fair condition this will work. If I want it sealed the first time, that is what I use. Just squirt some on the 2-3 thread and let if run around the pipe, then screw together. I can squirt it on the pipe from 2" away and it works fine but a little more wasteful.
They come apart but takes a little more effort than tape or paste but that works for me.
/ how do I get my NPT connections to not leak #26
If the threads are clean and dry I use Locktite 242 blue thread locker. If oily I use Teflon tape. I tried the liquid Teflon products many years ago but couldn't make them seal because they don't harden. They just pushed out at high pressure. Never tried them again. I rarely have anything leak.
It is the tapered thread that provides the seal, not any pipe dope.
Wow, lots of good suggestions. Many conflicting but that's the internet for you. :)
These connections are to things that only come in NPT, like quick couplers and valves. I've been using NPT to JIC adaptors and then JIC where I'm the one deciding what coupling to use. It's the NPT side of the NPT to JIC adaptors that I'm having trouble with. I replaced one on a quick coupler using a new adaptor and quick coupler and let it sit 24 hours and it's now good. One on a valve still leaks and it'll be the second time I've redone it. I don't have new parts for that one but this time I'll clean it with brake cleaner and let it sit a day before putting pressure on it. I may try loctite.
/ how do I get my NPT connections to not leak #28
I've had good luck using Permatex 54540, a little more expensive, but worth it.
/ how do I get my NPT connections to not leak #29
The fellows who state, "tighter is better" are spot on. And you can have bad threads, so if the threads are buried and you still got a leak, its time to start over with new fittings. Teflon is a lubricant, not really a sealant. One manufacturer i worked for discontinued the use of tape because it got into valves and messed them up, so they switched to Teflon dope only.
Arly, who spent years in the oil patch, watching the grunts assemble fittings, A
/ how do I get my NPT connections to not leak #30
BTW, in addition to what's been said, I'd recommend carefully examining the threads on both parts before doing anything. The few times I got bit in the azz with leaky NPT fittings, later examination showed defects in the threads. One time, it was obvious that the male fitting probably got dropped and was ever so slightly out of round. Another time, the male threads had a couple knicks and it was obvious they would never seal right. Then one time, the threads on the female part were not deep enough, so when it snugged up, it was nowhere near having the tapered threads engage. So now I carefully examine things beforehand. I also suspect a lot of the stuff coming from China doesn't have as good quality control, plus stores like Lowes/HD don't do the best job putting stuff on the shelf to prevent damage and you have customers rummage through them, etc... Lots of ways a fitting can be doomed even before you get your hands on it.
When I installed my water softener, it required so many PEX fittings and parts that I just put an order in at supplyhouse.com rather than go to the store and pick through the mess there. It was nice to get a box with everything I needed and the fittings were good quality and in good shape. For that project, I had to re-route the main line off our well tank and rework the supply route to the rest of the house and the hot water heater downstream of the softener, plus add in a bypass loop in case I ever need to bypass the softener, and add a future side leg for anything that may need unsoftened water. I took the opportunity to also plumb in a water line for my pier that had a backflow preventer and blowout leg. I ended up needing over 70 PEX and threaded fittings to do all of that. Not a single leak, knock on wood!!
/ how do I get my NPT connections to not leak #31
I use teflon tape and torque the crap out of hydraulic NPT fittings. (now don't use tape nor torque the crap out of SAE o-ring or JIC) but for NPT I find nothing works better than teflon tape (wrapped in the direction of the threads (so when you tighten you don't unravel the tape)).
Just made over a dozen NPT connections and none leaked using this method.
/ how do I get my NPT connections to not leak #32
Locktite 242, that's the response I got when I asked this question of a major hydraulic's vendor (here on this site). Since no threads are perfect (some are, of course, manufactured to a better tolerance than others) a sealer aids in filling in minor distortions.
Dry-thread to test how well the parts mate up (better to find out if you've got some binding [bad threads] before you get parts "gooped" up).
Clean/dry.
Apply sealant.
Tighten well and monitor.
Re-tighten if needed.
And, for hoses, make sure to NOT bend improperly (past allowable radius- resting and throughout operative range), especially right next to a connector/fitting.
/ how do I get my NPT connections to not leak #33
It sounds counter intuitive, but it is possible to over tighten these fittings and distort the threads. Its better to tighten them just a little snug, then tighten just a little more at a time if they happen to leak.
You are spot on. Most leaks in threaded pipe occur from overtightening. This is assuming that you have good threads to start with. A good lubricant is essential in either paste or tape form. Either when done correctly will not contaminate your oil (or whatever fluid) upon first use. Subsequent removal will require complete removal of the tape that is embedded in the threads prior to re-installation.
If you are using 1/2"-1.5" pipe, a 12" pipe wrench is large enough to tighten sufficiently using medium strength of a young man or maybe most of the strength of an old man. Anything more is likely damaging the threads. When fully tightened a threaded joint should still be showing about 1-1.5 threads on the male joint. Smaller pipe requires less torque to tighten so be careful not to overtighten.
As KYErik says, you can always tighten a bit more, but you cant untighten a stripped thread.
/ how do I get my NPT connections to not leak #34
It's simple. Don't use NPT for hydraulics. ;)
I wish that was an option. But for some reason a lot of hydraulic things come in NPT only, or the largest selection is NPT.
/ how do I get my NPT connections to not leak #36
I agree with the WOW factor. I thought if teflon tape was wrapped around threads right it wont get in to valve bodys, same as if the pipe sealant is not use right, that might also end up in somewhere.
What I like about teflon tape is no special cleaning on the fitting from the oil on the threads and or making sure it's perfectly dry with my helpers shirt, just wrap the tape around the right way and throw it together.
But since I'm open to new ideas I might try this stuff next time the hydraulic hose breaks>>> Amazon.com: Rectorseal 25631 4-Ounce No. 5 Pipe Thread Sealant: Home & Kitchen
/ how do I get my NPT connections to not leak #37
Tape is perfectly fine as long as you know how to apply it (keep it off the end threads- and if disassembling be sure none is inside any female end). The liquid stuff if misapplied won't cause any problems, so it's basically idiot-proof. I seem to struggle with pipe stuff. Took me a long time to get water plumbing down correctly. Had a lot of leaks with hoses to my rear remotes, but am hoping that I've got things taken care of now (I tend to under-tighten, fearing problems from over-tightening).
/ how do I get my NPT connections to not leak #38
I agree with using Teflon tape ( keep in mind there are more than 1 type) used keeping from the ends and you don't have to let it set before use . Oldpath keep in mind though I'm sure it will work most of the reviews were for low pressure gas for hydraulic applications I would snug up the joint and let it set for a few hrs.or more.
/ how do I get my NPT connections to not leak #39
A replacement I did back in 2014. I used plain old PTFE teflon tape. I used 21/2 wraps and kept it back up from the first two threads on the male end of the hose, and I screwed on the adapter. Finger tight, grip tight (wrench), and then a little extra. I pulled the new leaky hose off and put this one on - no leaks.
The thread sealer paste did not work for me.
Been 3 years - all is good.
/ how do I get my NPT connections to not leak #40
How do you make NPT connections that don't leak? Too many of the ones I added recently leak. I have been using permatex liquid PTFE sealer.
First, if we are talking hydraulic systems, DO NOT use plumbing fittings.
Hydraulic fittings are steel not iron and although the plumbing fitting will connect, it can distort, crack and create very dangerous high pressure fluid leaks.
Pipe threads can be tapered or straight. Most people don't know of straight pipe threads.
NPS = National Pipe Straight
NPT = National Pipe Thread
Both NPT and NPS have the same thread angle, shape, and pitch (threads per inch). However, NPT threads are tapered and NPS threads are straight (parallel). Both threads have a 60ー included angle and have flat peaks and valleys.
Tapered Pipe Thread is commonly found on ends of pipe, nipples and fittings (i.e. couplings, elbows, tees, etc.). Note: Sharply angled threads are very critical to joint being tight with no leaks. Thread sealant or tape is typically required to complete the seal.
Straight Pipe Threads need a gasket or O-ring to create a seal.
While NPT and NPS threads will engage, they do not seal properly with each other.
Tell us more about the situation(s) were this recurring leak is happening, perhaps even a photo or two.
Properly selected and properly used pipe threads should not be leaking nor hard to get to seal.
Sometimes, owners unfamiliar with serious hydraulic systems, are trying to seal joints using pipe dope or teflon when in reality the joint it meant to be one metal surface seating on another metal surface.
Automotive hydraulic brake lines are an example of this metal to metal design where a double flare is used. Propane lines using flexible copper use a single flare to seat against a metal fitting with a tapered face.
These are all lessons I had to learn the hard way over many years so I understand the confusion that can occur.
Dave M7040
2021 BOBCAT 566 R-SERIES SKID STEER (A60429)
2021 BOBCAT 566...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
DEUTZ MARATHON...
2007 KOMATSU GALEO D39PX-21 CRAWLER DOZER (A60429)
2007 KOMATSU GALEO...
2001 John Deere 6210 (A60462)
2001 John Deere...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
