how do I get my NPT connections to not leak
   / how do I get my NPT connections to not leak #21
Store bought or cut & threaded by hand? Seldom have issues with purchased fittings with a couple wraps of teflon tape ($1 a roll thread tape is not equal to ~$3-4 a roll tape) but have seen the threads cut to long by hand cause issues many times.
   / how do I get my NPT connections to not leak #22
I stuck with NPT fittings over the years mainly because they are cheap, readily available and easily adaptable to most other fitting types when necessary. I always buy quality fittings, don't over tighten and seal with blue teflon tape. I rarely have a leak.
It is interesting to see the many different types of thread sealants discussed in this post. Although I prefer teflon tape, I've read of instances where hydraulic systems were fouled with bits of tape. The dealer assembled all 6 of the tractors I bought from him using tape and says they have never had a problem. Has anyone here seen this happen?
   / how do I get my NPT connections to not leak #23
I thought this was Teflon Tape was for or am I on the wrong page again.
Teflon tape in a valve can be a bit of a worry. I use Rectorseal, tighten everything pretty well, run it until it's hot, and then hit the one or two that dripped. I've replaced a fitting once when I couldn't get it to seal.
   / how do I get my NPT connections to not leak #24
Working offshore on production platforms the last 30 years, it is almost mandatory that you carry a roll of Teflon in your pocket. We use the same tape on piping and fittings for water, oil, natural gas and air with pressures from vacuum to 30,000 psi. It can be black iron, stainless steel, plastic, cast iron, aluminum etc. Only difference noticed is if using quality made USA tape (takes less wraps) or the cheap Chinese stuff (breaks easy).
Some pneumatic panel shops prefer liquid or paste for fittings (mostly SS), they claim it less chance of it getting into fitting.
Sometimes no matter how much tape or paste used the fitting won't seal, then it's time for a new one. Also when screwing SS to SS put extra tape on, turn is slow and don't over tighten, otherwise you will probably gall the threads, when that happens the threads will lock together, destroying the threads, making it almost impossible to unscrew and possibly leak as well.
   / how do I get my NPT connections to not leak #25
I was a pipefitter for 20+ years and generally went against what others tried teaching me. Journeymen usually said to use tape and a quality Teflon paste (I forget the brand) in a squirt tube. Generally tape, even though put on correctly, was a hit and miss as far as leaking. If I feel like redoing it a few times I use tape.
Teflon paste generally works with very few leaks.
What I found that was 99.999% leakproof was Locktite 242. If the threads are in fair condition this will work. If I want it sealed the first time, that is what I use. Just squirt some on the 2-3 thread and let if run around the pipe, then screw together. I can squirt it on the pipe from 2" away and it works fine but a little more wasteful.
They come apart but takes a little more effort than tape or paste but that works for me.
   / how do I get my NPT connections to not leak #26
If the threads are clean and dry I use Locktite 242 blue thread locker. If oily I use Teflon tape. I tried the liquid Teflon products many years ago but couldn't make them seal because they don't harden. They just pushed out at high pressure. Never tried them again. I rarely have anything leak.
It is the tapered thread that provides the seal, not any pipe dope.
Wow, lots of good suggestions. Many conflicting but that's the internet for you. :)
These connections are to things that only come in NPT, like quick couplers and valves. I've been using NPT to JIC adaptors and then JIC where I'm the one deciding what coupling to use. It's the NPT side of the NPT to JIC adaptors that I'm having trouble with. I replaced one on a quick coupler using a new adaptor and quick coupler and let it sit 24 hours and it's now good. One on a valve still leaks and it'll be the second time I've redone it. I don't have new parts for that one but this time I'll clean it with brake cleaner and let it sit a day before putting pressure on it. I may try loctite.
   / how do I get my NPT connections to not leak #28
I've had good luck using Permatex 54540, a little more expensive, but worth it.
   / how do I get my NPT connections to not leak #29
The fellows who state, "tighter is better" are spot on. And you can have bad threads, so if the threads are buried and you still got a leak, its time to start over with new fittings. Teflon is a lubricant, not really a sealant. One manufacturer i worked for discontinued the use of tape because it got into valves and messed them up, so they switched to Teflon dope only.
Arly, who spent years in the oil patch, watching the grunts assemble fittings, A
   / how do I get my NPT connections to not leak #30
BTW, in addition to what's been said, I'd recommend carefully examining the threads on both parts before doing anything. The few times I got bit in the azz with leaky NPT fittings, later examination showed defects in the threads. One time, it was obvious that the male fitting probably got dropped and was ever so slightly out of round. Another time, the male threads had a couple knicks and it was obvious they would never seal right. Then one time, the threads on the female part were not deep enough, so when it snugged up, it was nowhere near having the tapered threads engage. So now I carefully examine things beforehand. I also suspect a lot of the stuff coming from China doesn't have as good quality control, plus stores like Lowes/HD don't do the best job putting stuff on the shelf to prevent damage and you have customers rummage through them, etc... Lots of ways a fitting can be doomed even before you get your hands on it.
When I installed my water softener, it required so many PEX fittings and parts that I just put an order in at supplyhouse.com rather than go to the store and pick through the mess there. It was nice to get a box with everything I needed and the fittings were good quality and in good shape. For that project, I had to re-route the main line off our well tank and rework the supply route to the rest of the house and the hot water heater downstream of the softener, plus add in a bypass loop in case I ever need to bypass the softener, and add a future side leg for anything that may need unsoftened water. I took the opportunity to also plumb in a water line for my pier that had a backflow preventer and blowout leg. I ended up needing over 70 PEX and threaded fittings to do all of that. Not a single leak, knock on wood!!
2017 John Deere 5090GN (A53317)
2017 John Deere...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2003 Big Tex 10PI...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2000 Volvo Semi (A59814)
2000 Volvo Semi...
Trailmobile Van Trailer (A56438)
Trailmobile Van...
