Snow plow cylinder diagram? Cushion Valve?
   / Snow plow cylinder diagram? Cushion Valve?
Similar. But, lets see if I can find a used one to adapt to the ssqa.
   / Snow plow cylinder diagram? Cushion Valve? #32
Where are you winthrop ...........
   / Snow plow cylinder diagram? Cushion Valve? #33
I'm in Maine also and I bought 2 a few years ago from the next town over. A nice 9'6'' Diamond for $200, in the above pic about the valve, (very good shape but needed both cyls) and a Fisher EZ - Vee 9'6'' for $450, missing one cyl. This is not the best time of the year to buy a plow, but ya never know.
   / Snow plow cylinder diagram? Cushion Valve? #34
Yes, do your research. Used plows.are quite affordable most places. Even if needing a little work....will still be money ahead if you know what you are doing.
View attachment 535230 If you make it like this you don't need lift chains
Not fond of the design because lack of float other than via the loader arms. And the loader arms add ALOT of weight when trying to actually float....and most times don't work well as the tractor tried to drive up over the plow. Ever try to float your loader bucket going forward....same scenario.
So unless you are plowing a flat lot.....or like adjusting the loader constantly.....design it with a chain lift like a truck
Winthrop Maine, Peter.
LD1 I really appreciate your input! I had not idea what was the chain lift. I watched some videos, I think I can easy make it. Thanks!!!!
About a used one, I cannot find anything less than $600. I do not know if it worth it since I still have to make the ssqa plate, and some push plates to attach it. It will save me labor, and I will have a better product but....
For the mold board I have not access to a roller or a brake. I was thinking of making it 3 angle (the cutting edge, a flat surface, and a top lip). I mean its not ideal, but the tractor has enough friction to push that anyway.
Right now I am plowing with the bucket in float position. Anything better than that will make me happy. :)
   / Snow plow cylinder diagram? Cushion Valve? #36
Email this guy on CL
Skid steer mount power angle fisher plow - $550 (Kensington NH00x0x_afItOJyac5d_600x450.jpg
   / Snow plow cylinder diagram? Cushion Valve? #37
Not ideal time to buy a plow, but still hard to fathom none locally under $600.
Gotta look for plow only. No pump or wiring.
Around here, about any week of the year you can find 4 or ,5 in the $200 range
Yeahh!!! $200 00Q0Q_3ty0i9TgUi7_600x450.jpg for the plow. So now I have to make some mounts and the ssqa plate. How about the cylinders, can I flush them to clear any contamination? I dont want to risk any damage to the tractor.
   / Snow plow cylinder diagram? Cushion Valve? #39
   / Snow plow cylinder diagram? Cushion Valve? #40
Yes it's a good idea to purge/flush cylinders.
Collapsing them won't purge it all, but will get most of it
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
Portable Restroom (A54865)
Portable Restroom...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
