Block heater trips breaker
   / Block heater trips breaker #31
I don't believe you can swap out a lower radiator heater fast enough not to dump the entire radiator and the upper portion of the block.
drain the radiator and install taking your time, why hurry and screw up.
   / Block heater trips breaker #32
X2, do it slow and do it right. Refill and use the tractor for 30 mins or so. Moving the tractor around and varying engine speeds will burp the air out.
Technically, since your heater is in the hose, it is called a "coolant heater" and not a "block heater".
DEWFPO
DEWFPO
Thanks. I don't mind draining the coolant but it also may be just as easy to clamp off the hoses - they're soft and about a foot long each, so if I clamp them near the pump, the leakage should be minimal. Any reason not to do this?
   / Block heater trips breaker #34
If possible, I would warm up the tractor good (if it will start) to make everything more pliable and easy to work with.
   / Block heater trips breaker #35
Is this a lower radiator hose heater or a tank heater?
Tank heater would have a couple of heater hose sized hoses one in and one out, that style you could just clamp the hose closed on.
   / Block heater trips breaker #36
Do not start your engine with the heater plugged in . causes it to burn out ( hot spots on the element )
   / Block heater trips breaker #39
As long as the hoses are soft and pliable and in good shape it shouldn't hurt anything. Just top off the radiator when your done.
DEWFPO
   / Block heater trips breaker #40
("Technically, since your heater is in the hose, it is called a "coolant heater" and not a "block heater".)<<<<<<<<<<<<In my mind that's a whole new ball game, should been brought out earlier in this thread, like maybe the first post.
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
