Block heater trips breaker
   / Block heater trips breaker #11
It doesn't look easy to get into the heater to replace the cord. Yes the breaker is GFI. Maybe just time to buy a new heater?
   / Block heater trips breaker #13
I had the same issue on a newer 20 amp circuit. Even drove to my neighbors new shop. same thing. We pulled my heater out of the hose and the element was just hanging there. Installed a new heater and all is well.
   / Block heater trips breaker #14
It sounds like the heater or the cord is your problem. You should be able to replace either individually. The cord can crack or split causing a trip, or the resistance wire can burn through to the outer tube also causing a trip.
   / Block heater trips breaker #16
I would start by plugging it into another circuit. Preferably one with a gfi. If it pops the breaker then the circuit is overloaded. If it pops the gfi then there is a short in the heater and/or it痴 power cable.
Now that sounds Genius. Never thought to troubleshoot that way.
   / Block heater trips breaker #17
Loose connections on outlets and circuit breakers can cause breakers to trip. Arc fault protection. All it takes is someone not tighten a connection. Since he replaced outlet and breaker, not the problem. Most likely problem is that the heater warms up, expands and and shorts out. It will test good with a meter and will only fail when it heats up. Replace the heater.
   / Block heater trips breaker #18
Actually, if it pops the GFCI then there is a ground fault. A short will pop the breaker.
   / Block heater trips breaker #19
A small short that is insufficient to pop the breaker will trip the GFI. That could be a short to neutral or a fault to ground because the gfi monitors the load across hot to neutral and trips if there is a variance. These are super sensitive and will trip before a breaker will.
So yes, I agree you are correct, but the real world dynamics of how they work allow you to investigate as I stated.
   / Block heater trips breaker #20
What happens when it pops a groundfault breaker? Is it a short or ground?
Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
Chevrolet...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
