FEL/pallet forks as scaffolding
   / FEL/pallet forks as scaffolding #31
I bought my drywall lift for $150 at Menards for that very same reason as I usually do projects over an extended period. I figured I could sell it on Craigslist after I was done but I have held into it. Mine only does 11' high ceiling though.
Here is a 15'' one for $300:
Troy Drywall Lift 15-Foot Panel Hoist Dry Wall - - Amazon.com
Here is a 19' one for $500:
Red Line RLP916 Drywall Panel 19' Hoist Lifter Dry Wall Lift Tool: Amazon.com: Home Improvement
Nice to have the extra height capacity, usually more stable. Mine is good at about 10' but beyond that it is shaky.
   / FEL/pallet forks as scaffolding #32
Ebay and Amazon are full of ones in the sub-$150 range.
I think getting the materials up and down is going to be a bigger challenge in this job than getting yourself up and down.
To me using the bucket as a man lift only makes sense if either you're going to be working in one spot for a long time and want something more comfortable than a ladder to stand on, or if you have a helper who can operate the lift so you don't have to climb. If you're going up and down a ladder anyway just use a stepladder.
   / FEL/pallet forks as scaffolding #33
But with the extra height capacity, check out the loading height. You might have to lift the sheets higher to load the drywall lift. A friend and I went together and bought one from Northern Tool. Jon
   / FEL/pallet forks as scaffolding #34
I had to use a pallet for a platform, working alone, using the ladder alongside it. Not the safest but I did work safe
The yellow man basket is a actually a double decker. Top section can be removed with four c clamps opened up and taken off.
If I had the smarts and access to one at the time, I would have used one of those totes. I don't think you can do it any better or cheaper than one of those.
   / FEL/pallet forks as scaffolding #35
Harbor Freight item 63050, $179.52 scaffold. I have one and they are great. Dry Wall Panel Hoist item 69377, $214.99. I have always been of the philosophy, rent something 3 times you might as well buy one. My life is worth more than $300. With a tractor you will be doing a lot of up and down and moving on a very unstable platform. I have done it once or twice for a one time thing. Would not relish doing it for several days.
Ron
   / FEL/pallet forks as scaffolding #36
Two points.
Plywood on the ceiling is not the best idea. It will cost a little more but liner panel metal sheets are lighter, easier to install, permanently painted in white. In a few years you will wish you used metal if you put up plywood.
Scaffold is much safer and easier to use than the FEL. I bought to used sections of rolling bakers scaffold and a high lift drywall lift to do my pole barn. I clamped the two sections of scaffold together to give a larger working platform. You may need to sections to get the height you need. My ceiling is just 12 feet. I'm not the most comfortable person with heights so I found having a larger working platform to be much more secure.
As an alternative, you might consider building a platform on your truck bed. I would do that before I used the FEL.
Ditto on the platform on the truck. Much safer. I spanned across the bed with 2x4s and a 3/4" piece of plywood and was very comfortable working at 12 feet. My old truck was a F-350 and was tall to begin with.
   / FEL/pallet forks as scaffolding #37
I guess I fit into the unsafe category. Here is how I built my barn. Used the homemade platform on the pallet forks every day.
   / FEL/pallet forks as scaffolding #38
I’m still waiting for proof it’s actually not safe. I know it’s not a certified lifting device, but I guess when we start looking for “proof” a lot more people have been injured by ladders. Which brings the question can someone find a single reference of someone getting hurt by doing this and were using a basket with a railing. Heck you can make it any combination of events you want as long as the injury was caused by malfunction of the machine and not falling off the platform.
   / FEL/pallet forks as scaffolding #39
I never did feel unsafe nor did it bother me that my son's were on the platform either. Of course, we were careful since no side rails were used. Heck if I followed all the OSHA rules I'd still be building it.
Thanks for all of the replies, very helpful. I'll check out a couple of the scaffold that you pointed out.
Final question: when using your tractor pallet forks as scaffold/ladder, did you leave the tractor running while you were up? I assume so to keep hydraulic pressure but thought I'd ask.
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2019 Chevrolet Silverado High Country (A56436)
2019 Chevrolet...
1604 (A57192)
1604 (A57192)
207279 (A52708)
207279 (A52708)
2008 CATERPILLAR 420E BACKHOE (A59823)
2008 CATERPILLAR...
Push Mower (A59231)
Push Mower (A59231)
