Shop Air Compressor set up questions?
   / Shop Air Compressor set up questions? #81
Oh .... ok. Good idea on increasing storage capacity.
Hockey puck vibration isolators ...... good idea and cost effective.
Guess I’ll have to stop by one of our local Hockey Pucks R US stores.
   / Shop Air Compressor set up questions? #82
I'd hafta make a couple stops to find pucks here. I'm guessing it'd be an all day event for your Rick. :D
   / Shop Air Compressor set up questions? #83
   / Shop Air Compressor set up questions? #84
I gotta get out more. If I happen to find myself in a Mall I can't figure out why they don't have a Sears or JC Penney's.
   / Shop Air Compressor set up questions? #85
I haven't gotten 'round to "permanently" situating mine yet. It's still on the original shipping blocks it came on back in 1979. IMG_4550.JPG
   / Shop Air Compressor set up questions? #86
Don't worry about it Terry. If it hasn't happened by now it probably isn't important. :)
Back in 79 the skid was made from hard wood... and put together with a little bit of care... in 2017 skids are made with no care, staples and wood sourced from grandmas flower garden. I didn't feel good about lifting the compressor on the skid with my pallet forks, one of the three legs was only on by 1/2"...:eek:
   / Shop Air Compressor set up questions? #88
Sadly true about a LOT of things nowadays....
   / Shop Air Compressor set up questions? #89
"it alive!"....well sorta.
After a expensive trip to a plumbing supply store. I had all I needed to plumb the compressor to the regulator.
There is not a lot of room in my closet, so when I installed the compressor I decided to make it easy for me to change the V-belt and compressor oil. By doing that I made it near impossible to see the pressure gauge.
I use 3/4" brass pipe fitting rated to 1000 psi for everything. The flex hose is rated to 300 psi, and the pressure gauge goes up to 160 psi (i should have got a 250 psi gauge).
my biggest hurdle was the limited space under the compressor for the drain line plumbing.
Dear all compressor manufactures,
Spend an extra 25 cents and make the legs on your compressors taller.... if you expect the end user to drain the tank every day... make it easy!
I didn't have room to install the 1/4" ball valve to the drain port, a buddy saved the day with some fancy fittings. when the weather warms up I'll run the drain line outside.
Polaris Side by Side (A50324)
Polaris Side by...
BUYERS PREMIUM & PAYMENT TERMS (A56138)
BUYERS PREMIUM &...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2012 PETERBILT 367 (A55745)
2012 PETERBILT 367...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
