DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #31
Has anyone used spacers along with load tires ? on a BX
Yes, I use the spacers with foamed tires, lots of hours, on my second set of foamed front tires, ready for a second set of foamed rear tires, and not problems Still a very good addition to my BX24.
   / DAMAGE DUE TO REAR WHEEL SPACERS #32
I successfully have been using the Bro-Tek rear wheel spacers for several years with no issues. My sloped hill-side ground makes my Kubota BX-25 much safer!
   / DAMAGE DUE TO REAR WHEEL SPACERS #33
Are your rear tires loaded ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #34
Are foamed tires as heavy a ones with rim guard (beet juice) ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #35
   / DAMAGE DUE TO REAR WHEEL SPACERS #36
NO wheel spacers on the front end with 4x4. No reversing front wheel rims. Bearings can not take the loads. Tractor will be more stable - setting in the garage with a broken front end.
   / DAMAGE DUE TO REAR WHEEL SPACERS #38
I found that out the expensive way as well. After maybe $1000 in repairs, I set the wheels back to narrow centered over the bearings and have never had an issue since.
   / DAMAGE DUE TO REAR WHEEL SPACERS #39
My front tires on the BX24 take 44 pounds of foam each. It has been so long that I don't remember how much foam went in the rear tires.
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2013 Express 20' Cargo Trailer (A57148)
2013 Express 20'...
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
2024 Load Trailer 20ft 7 Ton T/A Flatbed Equipment Trailer (A56858)
2024 Load Trailer...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
