DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #31
Has anyone used spacers along with load tires ? on a BX
Yes, I use the spacers with foamed tires, lots of hours, on my second set of foamed front tires, ready for a second set of foamed rear tires, and not problems Still a very good addition to my BX24.
   / DAMAGE DUE TO REAR WHEEL SPACERS #32
I successfully have been using the Bro-Tek rear wheel spacers for several years with no issues. My sloped hill-side ground makes my Kubota BX-25 much safer!
   / DAMAGE DUE TO REAR WHEEL SPACERS #33
Are your rear tires loaded ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #34
Are foamed tires as heavy a ones with rim guard (beet juice) ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #35
   / DAMAGE DUE TO REAR WHEEL SPACERS #36
NO wheel spacers on the front end with 4x4. No reversing front wheel rims. Bearings can not take the loads. Tractor will be more stable - setting in the garage with a broken front end.
   / DAMAGE DUE TO REAR WHEEL SPACERS #38
I found that out the expensive way as well. After maybe $1000 in repairs, I set the wheels back to narrow centered over the bearings and have never had an issue since.
   / DAMAGE DUE TO REAR WHEEL SPACERS #39
My front tires on the BX24 take 44 pounds of foam each. It has been so long that I don't remember how much foam went in the rear tires.
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
