DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #31
Has anyone used spacers along with load tires ? on a BX
Yes, I use the spacers with foamed tires, lots of hours, on my second set of foamed front tires, ready for a second set of foamed rear tires, and not problems Still a very good addition to my BX24.
   / DAMAGE DUE TO REAR WHEEL SPACERS #32
I successfully have been using the Bro-Tek rear wheel spacers for several years with no issues. My sloped hill-side ground makes my Kubota BX-25 much safer!
   / DAMAGE DUE TO REAR WHEEL SPACERS #33
Are your rear tires loaded ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #34
Are foamed tires as heavy a ones with rim guard (beet juice) ?
   / DAMAGE DUE TO REAR WHEEL SPACERS #35
   / DAMAGE DUE TO REAR WHEEL SPACERS #36
NO wheel spacers on the front end with 4x4. No reversing front wheel rims. Bearings can not take the loads. Tractor will be more stable - setting in the garage with a broken front end.
   / DAMAGE DUE TO REAR WHEEL SPACERS #38
I found that out the expensive way as well. After maybe $1000 in repairs, I set the wheels back to narrow centered over the bearings and have never had an issue since.
   / DAMAGE DUE TO REAR WHEEL SPACERS #39
My front tires on the BX24 take 44 pounds of foam each. It has been so long that I don't remember how much foam went in the rear tires.
MODEL 14C SCRAPER (A58216)
MODEL 14C SCRAPER...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
2018 Ford Transit 250 (A57148)
2018 Ford Transit...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
LOT: Landscape Timbers, Hand Tools (A59076)
LOT: Landscape...
