spray insulation
   / spray insulation #21
I paid $5k for the spray foam in my garage, Closed cell 4 inches in ceiling and 1 inch on walls. I have 6 inch walls, so added fiberglass bats over the foam to fill wall cavity.
The garage is 28X40
Dave
Great pics. Do you recall what R-value you got from the spray insulation??
   / spray insulation #22
I think you get 6- 6.5 R per inch for closed cell and about half that for open cell. The big benefit from the foam is not just the R value, but the air intrusion seal. So if you had the equivalent R value in foam and fiberglass, you'd still get improved performance from the foam. There's also a structural element too. The foam increases load bearing and wind load strengths.
   / spray insulation #23
gsganzer is correct 6-7 per inch. I was talked out of going thicker in the ceiling wanting to get around r-40. The foam guys said any over 4" would not be cost effective for central Illinois. Also have 2" foam board under the 5" concrete floor. The only weak link is the cement block stem wall, still work in process, any ideas how or what to apply? My current idea is to glue foam board to both inside and out and cover with another material. Used over 40 gallons of white paint and primer right after the foam was applied.
Dave
   / spray insulation #24
In regards to the concrete insulation. Friend of mine is having a 70x100 building erected. 42" poured footings with 2" foam board on inside. 6" floor poured on top with 2" foam board under it. Heated floor. He will still end up with the 6" face of his floor uninsulated. In the overall scheme of things, probably won't be noticed. And I see no way to overcome it.
   / spray insulation #25
I'm following with interest because I'm also considering something similar. Reading people's descriptions it seems like closed cell foam is stuck right around a dollar a board foot. For smaller jobs you can buy do-it-yourself kits, the one I'm looking at is the Dow Froth Pak. Their biggest kit is 600 board feet and seems to be around $700.
This website sells the big tanks -- up to 350 gallons -- and this chart shows how the cost of the raw materials goes as you buy bigger containers:
Dow Froth-Pak™ Refillable System – Board Foot Cost - Energy Conscious Learning Center
Even with the biggest tank the raw material is relatively expensive. And that 350 gallon tank ways 8,000 lbs!
   / spray insulation #26
Dow Froth-Pak Refillable System Board Foot Cost - Energy Conscious Learning Center
We used to use the "Foam it Green" kits at my last employer to seal some areas on insulated steel panel (ISP) buildings we fabricated. They work, but man are they a PITA and messy. There's definitely a learning curve. If you have any work stoppage of 20- 30 seconds, your nozzle plugs. Plan to buy a lot of extra nozzles with the kits. In fact, you want a whole extra gun and tubing assembly. You also have to watch that your nozzle doesn't get partially plugged and then blow off, spraying components everywhere. In other instances, you might not get both materials (Component A and component B) to flow equally. Again, unreacted components is a huge mess. None of it is easy to clean up.
   / spray insulation #27
It appears after a little cursory investigation, that the components require a minimum temperature and simple mixing to catalyze and polymerize.
If the chemicals are simply in a 'drum' they require pumping to the gun. The gun then has 3 things running through it.
1. Compressed air in order to distribute the chemicals from the gun to wall.
2. Chemical A and Chemical B
The gun is designed to provide the mixing of the agents. Obviously the 'Pro' guns do it in a different manner than the do it yourself versions which simply mix it in the nozzle. Thus, any stoppage results in the interaction of the chemicals in the mixing portion of the nozzle and thus clogging it. In the do-it-yourself kits, they chemicals are provided under pressure, thereby relieving the requirement for both compressed air for application as well as pumping of the chemical to the gun.
Is this about the gist of the situation?
   / spray insulation #28
I used the Dow Froth-Pak 600 when I re-insulated a wall in my house in 2010. I had some issues with the foam shrinking and delaminating from the studs. I contacted a Dow engineer and he said I had moisture issues in the wood. Dow sent a rep out to look at project. The house was built in 1983 and the wood was totally dry, moisture levels were well within spec and was not the issue. The engineer then send me a usage/installation manual for the Froth-Pak. One thing that was NOT in the directions than come with the Froth-Pak kit is the fact that if you spray on a layer of foam, you are NOT to spray over it for a minimum of 20 minutes!!! This little tidbit should be in the instructions but it is not. The Froth-Pak tanks must be kept between 70dF and 85dF for proper mixing and cure. I built a box to keep the tanks in and made a spot to install an electric heater to keep the tanks at the proper temp.
   / spray insulation #29
I DID FORGET to put my R value in w/ the foam board..
6.75 w/ 1" foil faced foam board. & I used 2".. so it musta gone up some.. doubtful it "doubled".. prob. in the hi 9's.??
I'm in Sunny South Carolina so cold wasn't a factor.. I just wanted something to keep the moisture & humidity down.. so it wasn't "raining" in the metal building..
The poster is in Georgia, so basically the same weather as myself..
Even w/ the snow storm we had last month it was tolerable to work in there.. I had the foam up & was sheeting the walls w/ plywood.
It wasn't "warm" but I had a propane turkey fryer goin for heat.. that was enough..
IF YOU THINK insulation is costly?? just wait until you get to wood & electric.!!! WOW..
I've spent about 3k on 1/2" BC plywood & JUST got a quote from the Electric Co. to run 200amp service 1750 ft.. $4500.00.!!!!
2 new poles, a transformer & face [cut the limbs] on about 100 trees.. 4502.00 to be exact..
& THAT is JUST TO the building.. that doesn't count the conduit, inside wiring, outlets or WIRE & breaker box..!!!
   / spray insulation #30
Sounds way too complicated. I just paid someone to do the walls of my cottage. The guys were real pros, and I would not want to try what they did. More than worth the money.
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2018 International DuraStar 4300 TMA Attenuator Truck (A52377)
2018 International...
2014 Dodge Ram 4500 Versalift Bucket Truck (A52377)
2014 Dodge Ram...
2008 Chevrolet Express Cargo Van (A52377)
2008 Chevrolet...
