Still in the research process for a new tractor for our mountain, farm, & client properties. Are Ag or Industrial tires tougher / stronger? When do you recommend filling them vs. not filling them? Pros/cons? Thanks!
Weighted tires help increase traction and add stability. Mine are filled with CaCl2. I now wish that they were filled with beet juice.
R1's (Ag) for field/dirt and mud operations. They will not load up as quickly as R4's. R1's have better traction on slopes = they will really tear up the lawn. R1's will "goo" forward in deep mud much better than they can "goo" in reverse. Once R1's really start loading up going forward one should start worrying about going in reverse.
R4's are a compromise. They have less traction and load up with mud and snow quicker. They do less lawn damage and with the stiffer/thicker tire with higher load ratings so they are more puncture proof and the front tires wear better than R1's for FEL operation.
There are many, many old threads comparing R1's to R4's. And many, many different/differing opinions by different owner/operators.
I am sure someone will imply that I am posting from where the sun does not shine, and that's OK with me.
Has OP also decided which is better, a gear tractor or a hydro?:stirthepot:
If you want maximum traction (without the use of tire chains) go with R1 radial ply tires. Just don't look at the sidewall bulge.![]()
