Ruger or Glock
   / Ruger or Glock #101
RSKY,
I have been in the similar decision process as you between these 2 pistols, but just got an email from the NRA that discusses their test results of the Sig P365.
Is it okay if I ask for comments on your thread about it? ...9mm, 10+1 capacity...about a half ounce more weight than the LC9s, but slightly less length and height...a tenth of an inch wider.
P365 | Sig Sauer
   / Ruger or Glock #102
To me the fact that you must pull a Glock's trigger before field stripping is a TOTAL non issue. If you didn't check the chamber of the firearm the instant you picked it up then you should not be handling firearms at all. Anyone that has a negligent discharge from pulling a Glocks trigger with the intent of field stripping it, is an idiot. And I would be happy to tell them that to their face. ALL firearms are loaded 100% of the time unless you have personally checked it right there and then. Anyone that would knowingly pull the trigger of a loaded firearm and not expect it to fire is an idiot.
   / Ruger or Glock #103
I was always told to double check the chamber by pros, your eyes play tricks on you sometimes
   / Ruger or Glock #104
Drop magazine, rack, look, rack, look, point in safe direction, pull trigger, continue disassembly procedure.
   / Ruger or Glock #105
That's the correct way , But not everybody does it that way
   / Ruger or Glock #106
Sounds perfectly reasonable to me. Guns are not negligent, people are.
   / Ruger or Glock
RSKY,
P365 | Sig Sauer
Sure it's okay. This thread has actually stayed on subject more than 90% do anyway.
Last night I sure got my mind changed on what I need to be carrying.
But IF I go back to looking at those two it will be the Glock.
RSKY
   / Ruger or Glock #108
How did you get your mind changed?
   / Ruger or Glock
We had a practice session for the church security team last night. Security team means a bunch of guys carrying concealed and just watching everything.
The guy leading the group retired from the military last year. Special Forces and has been training in the ME for a couple years.
Seriously, he had all us middle aged guys pointing fingers and screaming, "BANG, BANG," at the top of our lungs.
We rotated thru seven positions with one guy being the shooter. We stopped the shooter every time only loosing two or three every time. The drill was that the guy would be spotted pulling a pistol as he approached one of the doors.
Then the SF guy pretended to be the shooter. He killed all eight of us EVERY SINGLE TIME. Seriously, he bounced off the walls, was always moving, moved at a diagonal, and never moved straight toward anybody. He would be thru the foyer, up some steps and around a corner before we could get to cover or draw weapons. Then thru the hall and doors into the auditorium.
I think I may need more then six or seven rounds.
RSKY
   / Ruger or Glock #110
What he said x10
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
