Question for 5R Series Tractor Owners
   / Question for 5R Series Tractor Owners #1
mbarber84
Southwestern Pennsylvania
John Deere
Hi All,
I have a 5125R on order. The tractor should be delivered around May 2018. In anticipation of getting it, I`ve been reading over the operators manual available online. As I was looking at the lighting section, I noticed two paragraphs which referenced "additional front and rear work lights" that could be "added" to work in conjunction with the factory 2 fronts & 2 rears. Does anyone know anything about these? I cant find any information via the online parts catalog, and I made some phone calls to the JD info center with no luck. The 5M tractor we just sold (and will be replacing with the 5125R) DID have additional front and rear work lights. I purchased the kits myself and installed them. I would like to have as much additional lighting as possible on this new machine. A lot of my loader work is done in the evenings and into dark, and I do a lot of my pasture mowing after evenings. The additional lighting is always extremely helpful and I feel its a worthwhile upgrade. Any info you have would be greatly appreciated!
The representative I talked to at JD said that their copy of the operators manual was a revised copy from the one I was able to access online. They couldn't find any reference to these additional lights. If there are any current 5R series tractor owners on here, could someone take a quick look at their operators manual and see if anything is listed under the front and rear worklights? "SECTION 40 - ELECTRICAL AND LIGHTING OPERATION" I`m curious to see if maybe this was removed from the updated version of the manual.
I took 2 snap shots of the online manual as a reference. You`ll see the phrase about the additional lighting near the bottom where it says "NOTE:" with the yellow exclamation point. MANY THANKS!!!
   / Question for 5R Series Tractor Owners #2
I think there is only currently 3 options, convert the halogens to led, a beacon light, and a loader lights package. The conversion to led is just nuts and bolts but since this in an R series tractors if/when additional light choices come available they will need a software download for the tractor to recognize. So I don't know that I would count on just wiring in additional lighting in this application.
Yeah I saw that when I did the spec for my new one online. My current order includes the beacon light, the loader light package (both the ones mounted on the loader itself and the additional loader lights mounted to the front corner posts on the cab , the full LED work light package, and LED headlights. Im wondering what theyre referencing with when they say additional lights can be added? These tractors are so new that there is very little info currently out there for them. I know there was at least one member here who had recently purchased a 5R but I cant remember who it was. I wish I could see the page in their operators manual for lights to see if their book says the same as the one online. I also looked at the European spec version of these tractors but didnt see any reference to additional roof mounted lights. I wouldnt even think about wiring anything extra in. I would be buying OEM packages for sure. No need to take the risk with a $100,000+ tractor. :)
   / Question for 5R Series Tractor Owners #4
I bet there will be more options as time goes by, the r series in the 5xxx chassis is still a brand spanking new unit that is fundamentally quite a bit different from the e or m series tractors in the same chassis. From what I understand, for now, you have exhausted all of the oem lighting options.
   / Question for 5R Series Tractor Owners #5
Are these 5125 available in OS Model ?
   / Question for 5R Series Tractor Owners #6
Curious. What features on the R series got you to switch from the M series tractor?
I am looking at a similar size tractor and a straight side by side feature comparison seems hard to find.
   / Question for 5R Series Tractor Owners #7
The transmission options are the biggest difference between the two models.
   / Question for 5R Series Tractor Owners #8
The 32F speed would be SWEET
   / Question for 5R Series Tractor Owners #9
This chart shows some differences between 2018 5M vs 2017 5R. Couldn't find anything with 2018 5R specs.
   / Question for 5R Series Tractor Owners #10
The M / R bells & whistles sure runs the price Way UP :shocked:
Us Poultry Farmers likes the Pre Emissions 85-101hp E series :laughing:
There were several features that made me switch to the R.
#1 was the transmission. My farm borders a state road. Often times I have to come out of the field and travel the road to the other areas of the farm. The 5075M I had previously had the 16/16 transmission. The gears were synchronized but the ranges were not. Mine was a 2012 Model year, in subsequent years both the gears and ranges were synchronized. Having to stop to shift ranges makes it really difficult to get from field speed to road speed in any rapid pace. This makes it dangerous for me because traffic doesn稚 yield or respect farm implements these days. The new R is fully electronic and the gear shifts and range shifts are simple. Push button and done.
#2. Loader integration. The tractor I bought will primarily used as a loader tractor for handling round bales. The panoramic roof option gives you a really nice wide sunroof. This gives unparalleled vision when the loader is in the fully raised position. I値l enjoy this feature when I知 stacking round bales in the barn. In addition to th roof, the R tractor offers the electronic joystick with third function. I知 a fan of electro-hydraulic controls. It takes less effort and in my opinion makes the operation of the machine more enjoyable.
#3. Horsepower and weight. This tractor will be a better fit across all jobs in my operation. The added weight and horsepower over the comparable M tractors should allow it to perform better. If I need this tractor to do some light tillage, or run a discbine, it can easily do so.
#4. Premium cab. All the other larger tractors I have are premium level tractors. At the time when I bought my M, the increased creature comforts of the nicer cab weren稚 available. Having 20 years experience running the high-end tractors, when the opportunity to upgrade this tractor to a comparable level was enticing. Yes they are much more expensive, but in my humble opinion, if it痴 what you enjoy, and you can make it work financially, then it痴 a good move. I spend countless hours in these things on a daily basis so a little indulgence is warranted.
When my tractor comes in I am going to do an in depth full video review. I値l go over all the items and differences and post the video on YouTube. I値l keep you all up to date. I stopped at the dealership tonight by the way. I looked at the 5R they have sitting on the lot. It has threaded bosses both front and rear near the standard work lights so I知 assuming this is where the optional extra lights would mount. I also looked in the users manual. They still say 登ptional extra lights can be added / ordered so I知 still on the hunt fothe where / what these are.... we shall see!
   / Question for 5R Series Tractor Owners #13
Thank you very much mbarber84 for your detailed analysis!!
The 5R series is not available in an OOS configuration at this time as far as I know. I doubt it will be either. If the 5 series follows the other tractor series, only the E and M models will be available in OOS
No problem Kenny.
There are a bunch of other reasons the R tractors are more expensive. Youæ±*e getting a lot of technical advancements for the money. Closed center (pressure and flow compensating) hydraulics is one of them. Although it is an option, that feature alone is worth it for someone who does loader work a lot. LED lighting options are nice too.
The cab is significantly different from the M as well. They did a good job of increasing operator comfort. I知 anxious to get some seat time in the new one. I値l get that review done once the machine is in. Should be delivered first part of May.
   / Question for 5R Series Tractor Owners #16
I have been convinced on the R Series!
Separate issue... What should I be able.to expect as selling price goes? I went through the options and got the msrp, but what is a reasonable selling price? I am planning on a cash payment. 5% less% ? 10%? I can find invoice price listed for the 5090R that I am interested in.
My final price was about 22.5% less than the MSRP listed on the online builder but there were some costs not calculated in such things as tractor setup labor, tire ballasting, etc. There were also some incentives being offered when I put the order in for mine. I got $1,000 off any 5 series tractor and $500 bonus promotion. Ive also bought two 6420 tractors, one 5075M, three diesel Gators, one Kuhn GA7822 dual rotor rake, a 535 MoCo, a 275 disc mower, and an x758 ultimate diesel lawn tractor from this same dealer in the past 15 years so there was some loyalty discount in there too (not bragging at all, just wanted to put it in perspective)
I can tell you this for certain. I specd out an equal Massey Ferguson 5713SL and when the discounts finally worked out, I got the Deere about $10k cheaper than the Massey quote. I was pleasantly surprised.
You will not be disappointed by going with the R model. The price tag is hefty. I will not argue that fact. But you truly are getting more for your money. Everything about the premium Deere tractors is better. If youre able to make the money work, and you enjoy a nice piece of equipment, they are a pleasure to put in the field. We spent the money and got the premium 6420 tractors in 2003 and 2006 respectively and since that time, I have only ever had to send the 2003 back to the dealer once. They fixed the issue and both tractors have been incredibly reliable. Although I will give myself a small pat on the back as well because I run a tight ship when it comes to maintenance. I have no doubt that plays a part in keeping them running right for years and years.
I will keep you posted as I hear more about my machine. I am anxious to do a complete video review of it when it comes in. As of yet, there arent any real in-depth videos on the R series tractors on YouTube. (Or at least not in English anyway) these tractors are very popular in Europe from what I can tell.
No problem. I hope things work out for you. Do me a favor though, when you talk to your salesman, ask him about the extra front and rear work lights that they mention in the operators manual. I still cannot find any info on them. (See my original post in this thread for a detailed explanation)
If they are able to give you some info please share it!
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
TANK MANIFOLD (A58214)
1986 Ford LNT9000 Dump Truck (A61306)
1986 Ford LNT9000...
