Can my tractor haul a large rotary cutter?
   / Can my tractor haul a large rotary cutter? #21
Im enjoying the 租iscussion on TLB vs traditional tractors. Not sure why people think they are any different.
Not what I'll call a traditional tractor but when it comes to John Deere there is a differences between a JD 110 and a JD 110TLB.
The JD 110 is a lawn tractor and a JD 110 TLB is more of an industrial tractor.
John Deere 110
John Deere 110 TLB
   / Can my tractor haul a large rotary cutter? #22
Great pics of both machines!!!! When searching for a backhoe I looked at several JD110TLBs on CL. Man,,,, those things bring good money!!!!! Obviously highly respected and useful!!!!
There's a member on here that has a "collection" of older JD lawn/garden equipment It's a pleasure to see those old tractors!!!!
   / Can my tractor haul a large rotary cutter? #23
JD has a bad habit of using the same number for many different tractors.
   / Can my tractor haul a large rotary cutter? #24
Hey yall , looking for some wisdoms from the more experienced.
I own a kubota l39 TLB, 30.5 PTO HP. I am trying to find a bush hog that can cut thick brush. Probably 1.5? no bigger than 2?
I have found some medium duty bush hogs that meet all my needs but state a min PTO HP of 30.
Can I haul these? Can I turn them? I prefer to be conservative and definitely dont want to damage my tractor.
Any advise?
Thanks
The 田onventional wisdom is you need 5 hp per foot of width. I violate that rule every time I run my hog. My machine is like 18 hp at the pto.
I just can稚 cut thicker stuff as fast as others or really thick stuff at all.
That said I have used my light duty hog to munch up the occasional 1.5 to 2 inch sapling. I go dead slow. I wouldn稚 want to do a lot of that.
Mostly use mine for horse pasture. However waist high weeds I can take a full width pass and go as fast as I care to go.
Ok Doc, haha, there is definitely more difference in your case.
   / Can my tractor haul a large rotary cutter? #27
A Howse 500 is an economy cutter. A 285 Bush Hog is a medium duty cutter. Not the same class cutter.
Yes I am aware of this, thank you.
The Howse is rated for 1.5” and the BH is 2.5”
Both would work for what Im doing, but of course the BH is stronger.
I've been looking at the 6ft brush cutter from Everything Attachments.
That might be the way to go.
Near the end of the video (14:50) he cuts down some very large trees!
Xtreme Duty 72 Inch Brush Cutter by Everything Attachments - YouTube
That cutter is definitely doing some work. Im looking more at 4’ and 5’ cutters since my work will be done mostly in the woods and I dont mind the smaller cutting area. My main focus is the cutting Capacity and the risk for overworking my tractor.
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A56129)
2015 FREIGHTLINER...
2012 Dodge Journey (A53314)
2012 Dodge Journey...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
