Can my tractor haul a large rotary cutter?
   / Can my tractor haul a large rotary cutter? #41
My L39 TLB is a Glide Transmission. Will that adversely effect something?
My mistake I thought I read somewhere that you had hydrostatic. No big deal to shift gears if you need to, though slightly more annoying than a hydrostatic.
   / Can my tractor haul a large rotary cutter? #42
Not criticizing, just clarifying. Hydro is water. Hydra is hydraulics.
   / Can my tractor haul a large rotary cutter? #43
Hydrostatic transmissions don't use water. :D
Hydro is a prefix, which denotes used of liquids - water is the most common liquid.
We are getting off topic though.......
   / Can my tractor haul a large rotary cutter? #44
I've heard many times here the rule of 5hp/foot, but think larger trees this size might take more. Plus, you'd probably need a tougher housing than what's in a typical bush hog.
Ralph
   / Can my tractor haul a large rotary cutter? #45
Ralph
I'm not sure that I completely buy the hp/ft rule. Maybe if you are looking to move fast, but if you are ok going slow it's not much of an impact in the HP ranges we are talking about here.
I find that the momentum of the blades are what help make a cut on a sapling. The HP of the tractor will just affect how quickly you can hit the next sapling.
Heavy blades and a robust gearbox will help - since heavy blades are less prone to swinging out of the way instead of punching through.
OP what kind of saplings are you cutting? I find maple are tough, but I could mow a field of pines with no concern. Also, if the saplings are spaced, you'll have a much easier time breezing through than if they are tightly spaced.
   / Can my tractor haul a large rotary cutter? #46
With a FEL, mowing thicker brush, I would push the brush into a pile rather than trying to mow it, if the bush hog doesn't like mowing the brush. A tooth bar on the FEL might make ripping the trees out by the roots easier, depending on the soil type. No sense in beating up a mower just to clear land, unless the mower doesn't mind it. Be careful not to twist the FEL pushing on brush, but if it is close to mowing size, it probably won't hurt the FEL.
David from jax
   / Can my tractor haul a large rotary cutter? #47
Okay.
Agreed, my Kubota had the glide shift and if I came to a spot that was thicker and needed to slow down, I just dropped it a gear or two if need be then bumped it back up when I got through that spot.
Thanks for the great advice! Ill keep that in mind. Hoping to do some cutting soon!
Most of the cutting will be through thickets and bushes. A real assortment of kinds. I’m planning on going real slow and even backing up to some if I have too. I h am not in any rush. This is an area I am clearing to build some houses, so I am only planing on cutting it once.
   / Can my tractor haul a large rotary cutter? #50
I was worried about my PTO hp also when I bought my rotary cutter last year. I ended up buying a Woods BB600X. I have 35 PTO hp and have used the cutter a lot since buying it. It will eat up pine saplings and brush like they are not there. I probably would of been fine with a BB60X or BB72X also but wanted a heavier duty cutter for the type of work I am doing with it.
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2018 Bobcat E26 Mini Excavator (A55787)
2018 Bobcat E26...
John Deere BD1108 (A50123)
John Deere BD1108...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
