Space heater
   / Space heater #11
Oil filled works well. I have used a DeLonghi for about 20 years to add supplemental heat and it still works. If you get one make sure it really has a thermostat if you need it. Most just have adjustable power level.
Same here. I have two but rarely use them.
   / Space heater #12
If I get up around 4 and put more wood in my stove will make enough heat except for the week or so of the coldest weather. Then the natural gas furnace has to help a little. I just leave the natural gas thermostat set at the bottom end of our comfort level. It doesn't kick on very often.
   / Space heater #13
Drink a couple of cups of tea just before bedding down. Then throw a couple of fresh logs in the fire when you get up to go to the can, three times.
LOL, when you get to a certain age your prostate will wake you on schedule about every 3-4 hours and that's not to remind you to feed the stove.
   / Space heater #14
I don't have to drink a couple cups of tea. Up in the middle of the night - out on the porch, under the starry skies. OH - crap - the porch has frosted over - slick as snot on a doorknob. I dance around like a drunken sailor - finally stabilize the situation - get the job done. Just another night and I didn't fall on the porch.
Oh - and yeah - check the inside temps and adjust the space heater if needed.
   / Space heater
Thanks for all of the replies. I just ordered this one. (DeLonghi TRD40615T) This heater will be used at our place in the mountains where we spend a lot of time. It will only be used at night to knock the chill off in case the wood stove burns down. Normally I sleep pretty much thru the night, prostate not on the 3 hour schedule yet thank goodness, so unless my wife awakes & feeds the stove, it does burn down. That makes for a chilly downstairs. Hope this works.
   / Space heater #16
I have such a heater. Mine is called Aloha Breeze, is two temperature (1300 & 1500W) with a variable thermostat and built in fan. It runs on 110V. I recently had it plugged in for an entire month in my unheated basement to keep some pipes from freezing and saw my next electric bill go up by $100. As soon as I saw the bill I realized I had forgot the heater was on and went down to unplug it.
Generally my basement stays in the mid 40 deg. F but the PVC piping to the house runs along an outside wall in one area and has frozen during real cold spells.
The good thing for you is with a themostat controlled electric heater it won't come on until the wood stove goes out and the room temp drops to the point the heater kicks on. The bad part is I don't think a 1500W heater is going to do much in a large room you mention.
I actually have two electric heaters (the 1500 and an 1800W) and usually only use them to load test small generators.
. 1300W and 1500w is a measurement of power , not temperature .
   / Space heater #17
we have one, and i think they are a good choice, with the thermostat it will start coming up in temp as the room cools down.
i believe it has a timer function also?
   / Space heater #18
   / Space heater #19
Just be thankful it wakes you up. :D
   / Space heater #20
I know that. Mine has two knobs. Top knob has Off-fan-1300W-1500W positions. Lower knob is a thermostat which turns it on-off via temperature.
UNUSED MOWER KING SSEFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
