Space heater
   / Space heater #1
buckbros
Maryland
john deere LT180, John Deere GT235, 1950 Case Vac, 2 Gravely L Models
I am thinking of buying a space heater to heat add some heat after the wood stove cools down. (before I awake)
It will only be a 1500 watt heater. Anyone have any ideas. The room where my wood stove is in is pretty large.
   / Space heater #2
I have such a heater. Mine is called Aloha Breeze, is two temperature (1300 & 1500W) with a variable thermostat and built in fan. It runs on 110V. I recently had it plugged in for an entire month in my unheated basement to keep some pipes from freezing and saw my next electric bill go up by $100. As soon as I saw the bill I realized I had forgot the heater was on and went down to unplug it.
Generally my basement stays in the mid 40 deg. F but the PVC piping to the house runs along an outside wall in one area and has frozen during real cold spells.
The good thing for you is with a themostat controlled electric heater it won't come on until the wood stove goes out and the room temp drops to the point the heater kicks on. The bad part is I don't think a 1500W heater is going to do much in a large room you mention.
I actually have two electric heaters (the 1500 and an 1800W) and usually only use them to load test small generators.
   / Space heater #3
Whatever you get - don't leave it on when you leave the house. Guy down the road lost his entire house to a stupid overheated space heater. Fortunately - nobody was hurt.
   / Space heater #4
We have a 3500w inverter reverse cycle aircon and wood heater, it is quite efficient and we use it when we need a warm room and are not going to be home for long or when we get up.
About 5 minutes gets the room comfortable and is enough to keep it warm while the wood heater gets going.
It is a lot cheaper to run than a small heater as the air circulation is much more efficient and gets the job done in a very short space of time whereas a space heater will take a lot longer and run up the power bill.
   / Space heater #5
I like oil filled heaters. They take awhile to get up to heat, but they put out steady heat after that. Not much worry about setting something on fire. Granted, no instant gratification.... but fine by me. I have three in a closet for backup heat if my furnace goes out. Along with a gas kitchen stove and a ventless wall heater. Use one of the oil filled early in the fall and late spring when the furnace is shut down for the season.
   / Space heater #6
The money you spend keeping the room warm after the fire goes out might be better spent with insulation or other methods to extend the time that the wood stove stays warm, since this is going to be a continuing issue. Is there a way to shrink the size of the room, increase the burn time on the stove, or go to a larger stove, or better efficiency stove? Just my thoughts, as I hate to see you use a space heater that isn't really large enough, or if it is, won't be cheap.
David from jax
   / Space heater #8
Drink a couple of cups of tea just before bedding down. Then throw a couple of fresh logs in the fire when you get up to go to the can, three times.
Thinking outside the box here. I know when i get up in the early morning, the stove is still throwing some heat, and the house is well insulated, so that the temp doesn't get below 65 till that evening.
   / Space heater #9
Why not do what I do, get up in the middle of the night, add some wood to the stove, take a pee and go back to bed. I wake up and roll over about every 2 or 3 hours anyway. I fall asleep faster on an empty bladder so another plus. If it is a nice night take a whiz outside even better.
I despise paying utility bills. Our power comes from hydro dams paid off eons ago but we still pay much more than we should. So I pinch on the electrical usage for spite.
   / Space heater #10
Oil filled works well. I have used a DeLonghi for about 20 years to add supplemental heat and it still works. If you get one make sure it really has a thermostat if you need it. Most just have adjustable power level.
   / Space heater #11
Same here. I have two but rarely use them.
   / Space heater #12
If I get up around 4 and put more wood in my stove will make enough heat except for the week or so of the coldest weather. Then the natural gas furnace has to help a little. I just leave the natural gas thermostat set at the bottom end of our comfort level. It doesn't kick on very often.
   / Space heater #13
LOL, when you get to a certain age your prostate will wake you on schedule about every 3-4 hours and that's not to remind you to feed the stove.
   / Space heater #14
I don't have to drink a couple cups of tea. Up in the middle of the night - out on the porch, under the starry skies. OH - crap - the porch has frosted over - slick as snot on a doorknob. I dance around like a drunken sailor - finally stabilize the situation - get the job done. Just another night and I didn't fall on the porch.
Oh - and yeah - check the inside temps and adjust the space heater if needed.
   / Space heater
Thanks for all of the replies. I just ordered this one. (DeLonghi TRD40615T) This heater will be used at our place in the mountains where we spend a lot of time. It will only be used at night to knock the chill off in case the wood stove burns down. Normally I sleep pretty much thru the night, prostate not on the 3 hour schedule yet thank goodness, so unless my wife awakes & feeds the stove, it does burn down. That makes for a chilly downstairs. Hope this works.
   / Space heater #16
. 1300W and 1500w is a measurement of power , not temperature .
   / Space heater #17
we have one, and i think they are a good choice, with the thermostat it will start coming up in temp as the room cools down.
i believe it has a timer function also?
   / Space heater #18
   / Space heater #19
Just be thankful it wakes you up. :D
   / Space heater #20
I know that. Mine has two knobs. Top knob has Off-fan-1300W-1500W positions. Lower knob is a thermostat which turns it on-off via temperature.
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61306)
Midwestern...
Club Car Utility Cart (A55851)
Club Car Utility...
SAMSUNG REFRIGERATOR/FREEZER (A60432)
SAMSUNG...
3015 (A56857)
3015 (A56857)
