Cheap Start to Reloading?
   / Cheap Start to Reloading? #81
shoot a revolver and never hunt your brass. ;)
Anyone experienced with Berrys Plated bullets. Specifically, 115 gr 9mm? I shot some with 5.2, 5.6, and 5.9 gr of CFE Pistol, from a Hi Point 995 Carbine. uploadfromtaptalk1520465711692.jpg Shot into 3 gallon jugs at 15 yards, went into ground after 2nd jug. Does this seem normal? The copper jacket is gone from where the rifling engaged the projectile.
Anyone experienced with Berrys Plated bullets. Specifically, 115 gr 9mm? I shot some with 5.2, 5.6, and 5.9 gr of CFE Pistol, from a Hi Point 995 Carbine. View attachment 543023 Shot into 3 gallon jugs at 15 yards, went into ground after 2nd jug. Does this seem normal? The copper jacket is gone from where the rifling engaged the projectile.
   / Cheap Start to Reloading? #84
I have been watching too much YouTube, and now am seriously thinking about starting reloading. My thought is Lee Breech lock $35 press, Lee 3 die set ($35), Lee Ram Prime ($15), Lee Powder scale ($25-30) or Frankford Arsenal ($30). Powder ($30/#), Primers ($4/100), Projectiles ($20/100). Do you think it's doable to get started (equipment and consumables), for less than $150?
As another option, I inherited an old Lee Landloader for .270 Win, that's in questionable shape. Would powder, primers, projectiles, and a scale with this be a good starting place? Am I better off using this money to buy factory brass ammo for another year, and think about this at a future date?
.270 Winchester (bolt)
6.5 Grendel (semi auto)
7.62x39 (semi auto)
7.62x54 (bolt)
9mm Makarov
9mm Para
.40 S&W
7.62x25
.410 (single shot)
12 Ga (pump)
I have a Dillon 550 and reload pistol only. Here is my suggestion:
First, decide what you are reloading for. I shoot USPSA, so .40 and .45 are used like candy. This makes economical sense.
7.62x39 just isn't worth it. I look at it like 556. Cheaper to buy unless you want match grade ammo.
You are going to need multiple die sets for al of these calibers as well.
Check out Freedom Munitions online. They are reasonably priced ammo. I buy thousands of rounds of 9mm and 556 from them. All great stuff.
Perhaps reloading some of the rifle rounds makes sense. Start with something common like .270 or the 6.5G and work your way from there.
   / Cheap Start to Reloading? #86
Did you find the electroplated jacket I the jugs? My understanding is it is only for reduced leading in the barrel and not a structural jacket.
I did not, but it could be in the sand around the jugs.
   / Cheap Start to Reloading? #88
Check your barrel.
All that holds the plate on is the friction with the soft core. The strength of the foil like jacket is insignificant. If the friction of the jacket to the barrel is greater than the friction of the jacket to the core, the core could"squirt" out of the jacket.
   / Cheap Start to Reloading? #89
Those Berry's are copper plated, not jacketed, so what you're seeing is not unusual, just a good tight bore and riflings. I've reloaded and shot thousands of them, but at James mentioned, I've switched over to coated bullets since they've got the prices down to being compatible with plated bullets.
If you're really concerned over it, shoot an email to Berry's, they are really quick to reply to any questions or concerns.
   / Cheap Start to Reloading? #90
I have reloaded and shop thousands of Berry's and other manufacturers plated bullets and recovered many of these bullets that I shot. In 380, 357 and 45 cal and have not seen any that lost their plating along the rifling. Your picture to me indicates either too tight a fit or too hot a load. Bob
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2011 INGERSOLL RAND  G25 GENERATOR (A50854)
2011 INGERSOLL...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
