How to you store the random oil jugs?
   / How to you store the random oil jugs? #1
Olympus
Cape Girardeau, MO
LS R3039
I’m finding that I’m collecting all sorts of different partial quarts of oil from all the various machines I have. They’re starting to take over my work bench. Does anyone have a better storage solution for their various partial quarts of oil?
   / How to you store the random oil jugs? #2
Yep, same problem here. I have been switching everything over to one oil. That seems to be the best solution for me.
I’ve got too many things on different oils though. 5W-20 for car/truck, 15w-40 for tractor, 0w-40 for Ranger, 10w-40 for ATV, 2cycle oil for little mans ATV, 2cycle mix oil for chainsaw/trimmer, etc.
   / How to you store the random oil jugs? #4
I have been switching everything to Rotella T6. Makes life much easier. A 5W-40 synthetic oil will cover a broad range of applications.
   / How to you store the random oil jugs? #5
Does that work with gas engines also? I have been using mobile one in gas and the Rotella synthetic in diesels.
On two cycle found an oil that works for my all my two cycles. So using three.
   / How to you store the random oil jugs? #6
I don't end up with very many partial quarts. The few that I do either live under the hood or on a shelf.
   / How to you store the random oil jugs? #7
At one time, a few years back, there was talk that the diesel engine oils were harmful on gasoline specific catalytic converters. I personally have found no real evidence of that thru my research. I have a combined 240,000 miles on two Toyota Tacoma's and I run T6 in them with no negative results.
There is a new Rotella T6 product that claims it is designed for gas and diesel engines. I haven't seen any in my neck of the woods yet.
   / How to you store the random oil jugs? #8
First world problems , LOL Buy an older tractor that burns oil and you will soon find you never have enough to top it off . If its really an issue just dump it in the diesel tank and burn it,
   / How to you store the random oil jugs? #9
Where I live I use the same 0W40 oil in everything except the Bobcat, but that will change with the next O/F change.
DEWFPO
   / How to you store the random oil jugs? #10
I tend to buy oil well ahead of time, on sale when I can. When I change the oil in something I wind up with fewer containers than I had before, even though there's usually one partial container left. They go in a cabinet with the other oil, with the vehicle name written on them if it wasn't already.
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
Terms and Conditions (A47477)
Terms and...
2019 FORD F-250 XL SUPER DUTY SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
5' S/A CART (A52706)
