Dftodd
Super Star Member
- Joined
- Oct 19, 2014
- Messages
- 10,649
- Location
- vilonia, arkansas
- Tractor
- Massey Ferguson 1825E, Kubota Z121S
The piece I was pressing shifted slightly at around 18 tons. Had some bearings that were a bear to press off. Giving them some mojo and the press blocks and shaft shifted. That bit of an angle caused the guide tubes to bend. At the same time the shaft shot out into the wall. Guide tubes were around a 22 degree angle when things settled down.
Think the one we had was purchased from Grainger, and the return springs road the guide tubes.
We replaced it with a 30 ton air over hydraulic. I beam is a little narrower but still able to fit the 3" od shafts. The way the piston mounts is much more stabil as well.
Had a 100 ton electric hydraulic st the last shop I worked for. That thing was insane. But it also came with a ballistic enclosure. Used to press bearings in and out for idler sprockets on a 24 ft trencher. Think ditch witch on mega steroids
Getting the old bearings out used to make that 100 ton press grunt
used to get everything lined up with the ram holding tension on the the piece. Then would lower the ballistic shield and stand behind a cabinet.
