Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,971
That was great !! Thanks OldP. I can see that is not the first time you did that. That trailer stays put better than I thought it would. Good to see that. You know how to get the most out of that tractor/trailer combo. Thanks again.
gg
   / Tractors and wood! Show your pics #5,972
You just have to watch out for the rear end coming off the ground, when you load BIG logs!
SR
   / Tractors and wood! Show your pics #5,973
I pulled out some big logs which sadly won’t make saw grade. 2 at a time was really a bit much to handle but I had to see if it had the muscle to do it. My l3240 would have never budged one. IMG_4001.JPG
   / Tractors and wood! Show your pics #5,974
OldP - I should add that you put guys like me who use a grapple to shame. You certainly know how to make those little stubby prongs on your bucket work !
gg
   / Tractors and wood! Show your pics #5,976
"or are you loading from a pile that you previously skidded to a landing or bunching area"1> Yes from a bunched area in the woods. 2>> yes trailer is unhooked from tractor, I'll try another video link of loading logs>>>> Logging - YouTube 3>>trailer hitch is on the winch when in use, picture time>>>>>>>>>>
View attachment 549375 View attachment 549376 View attachment 549377 View attachment 549378 View attachment 549379 View attachment 549380 View attachment 549381
Pic 1>>>temp use, 2,3,4>>trailer hitch ready for hook up use with extra 1/2" case harden bolt to keep the hitch from swinging, 5>>>hitch not in use and stowed behind front tire on loader mount, 6&7>>>2" receiver welded in the winch.
Impressive work! You’ve turned that machine into an aggressive beast.
I see your Rhino back there. How do you like it? (I don’t want this derailing like I did with the saws). I just get excited. With that, I keep getting advertisements for Dolmar / Makita saws. I’ll have to find a thread on those. Pro saw for 20-30% less than stihl.
   / Tractors and wood! Show your pics #5,977
You know how i feel about Dolmar saws
   / Tractors and wood! Show your pics #5,978
Makes sense.
Everything convincing me to buy a log trailer makes a lot of sense !!!
Thanks
And if buying a trailer, best to have tandem axle, even nicer to have a log loader on a trailer.
   / Tractors and wood! Show your pics #5,979
SR
Do you have ballast in your tires? probably with your tractor you can get by without it.
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
40ft Sea Container (A52384)
40ft Sea Container...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
