135 Locked up on startup!
   / 135 Locked up on startup! #11
Ok Which one is the gearbox filler hole? I just tried again and as soon as you feel some resistance in the clutch i can turn the engine over. In the top 1/3rd of travel i'd say. That and the fact that i was able to roll the tractor with my trucks help tells me its not stuck in a gear. I think?
I think you locked it in gear AND sheer the sheersleeve that connect the box to the diff ?
I wouldn't be able to roll it if it was locked in gear though right? I took this pic through the hole. It appears to move between gears ok. This pic is neutral.
Yes for the left rail!
And the big gear ?
The one on the left of the pic? It moves back and forth with the lever. And i'm in Belleville, Ontario Canada.
Hey ya still :( Check this out. I found these marks / cracks with a Borescope. This is looking forward from the fill hole. This has to do with the Multipower I think?
3pt Hay Spear (A56469)
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
1784 (A57192)
1784 (A57192)
Blue Diamond 72" Quick Attach Bucket (A56469)
Blue Diamond 72"...
CAT 259D (A53317)
CAT 259D (A53317)
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
