Any 4610 owners have problems with their tractors?
   / Any 4610 owners have problems with their tractors? #91
I think i am having the same rattle you are talking about. My tractor makes a rattle sound which I was contributing to the transmission. I have an intermittent rattle when in gear until i push on the clutch or put the lever into neutral. Sometimes it worse than others and sometimes it goes away completely. It is usually worse in low than high. Is this similar to the rattle you are talking about. Id really like to get mine fixed if its something that going to do more damage, talking to the dealer over the phone he thought it might be the transmission flex plate.
Take the tractor in and get that flywheel and clutch replaced if it's not out of the 5 year powertrain warranty.
   / Any 4610 owners have problems with their tractors? #92
i had no idea it might be under warranty. it is a 2014 tractor that i believe was bought in 2015 but i am second owner. do you have any idea it it was a transferable warranty
   / Any 4610 owners have problems with their tractors? #93
Not a clue. That's between you, the last owner, and the dealership. I just know that it's a warrantable rattle.
   / Any 4610 owners have problems with their tractors? #94
you sound like you might be familiar with these tractors. does this noise sound like it might be the flex plate or the flywheel dampener that linemanluke was talking about
   / Any 4610 owners have problems with their tractors? #95
I'm not 100% certain but my guarantee on a new 2011 was only 2yrs. Someone said it is 5yrs now ??
I am not sure of it was my MF2660 or another machine (and yours could well be different) but isn't the throw out bearing in constant contact on these machines ? Runs full time ? Maybe not. If it is not full-time then maybe you are taking up slack (that allows rattle) when you touch the clutch. Another thought is that depressing the clutch pulls the pressure plate away from the flywheel so maybe some of the pressure plate springs are either loose or busted ? Wait a minute -- is that not a wet clutch !?
OK, I give up. Don't know enough of your machine to help.
For sure go in quick and get the dealer to register the existence of the problem on a particular date & see if it is under warrantee. That's not necessarily the same thing as demanding a clutch replacement.
   / Any 4610 owners have problems with their tractors? #96
im taking it down to the dealer on saturday. i would love it if it was under warranty but i highly doubt it with my luck. im just hoping its not something that requires splitting the tractor apart and really hoping its not something that requires pulling the cab apart but it sounds like its going to be. does anybody have a ballpark idea about how long it should take to replace the clutch and flex plate?
   / Any 4610 owners have problems with their tractors? #97
You're doing the right thing -- get the dealer's evaluation. But kind of like testing for cancer -- don't believe something horrible until it is proven.
   / Any 4610 owners have problems with their tractors? #98
The noise originates from the damper. I am told there is a new damper that is being released this spring/summer. MF has advised that there have been no failures that have been the result of the noise. Agree it is a nuisance but I can honestly say have we not seen any drive line failures on tractors that are caused by the damper.
   / Any 4610 owners have problems with their tractors? #99
Let me know what they say. And yes yours is out of warranty as well as mine. I was also second owner and it was only 2 yr warranty.
   / Any 4610 owners have problems with their tractors? #100
I wonder if they will replace the dampers on these tractors since it seems most people's 4600 series seems to do it. Kinda like a recall?
2019 Chevrolet Silverado 1500 (A55973)
2019 Chevrolet...
John Deere 1025R (A53317)
John Deere 1025R...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2016 Ford F-550 Altec Bucket Truck (A55852)
2016 Ford F-550...
2020 FREIGHTLINER M2 26' BOX TRUCK (A57192)
2020 FREIGHTLINER...
